turbo not boosting
Old Jul 21, 2007 | 06:04 PM
mikelomax's Avatar
mikelomax
MOUSE
Default turbo not boosting
ok small problem. just fitted my t4 turbo and all new reinforced hoses. just took it for a short test drive and there was no boost, the turbo was hardly spooling.
not had time to give it a good checking over but i did quickly check all the hoses were on properly and nice and secure.
im gonna have a good look at it in the morning now but i just thought i would put up a little post to see if anyone had any odvious solutions before i get annoyed tomorrow.
as it is a brand new turbo from turbo technics with actuator. would it be setup to go straight away??????
probably something i have missed because i was rushing as my wife was nagging at me to come in the house and look after the little one.
mike
Old Jul 21, 2007 | 06:27 PM
cosy trav's Avatar
cosy trav
i should imagine it will be set up but check it . if its set up on the actuator check you have connected the pipes up correctly on the amal valve .
Old Jul 22, 2007 | 10:29 PM
Stu @ M Developments's Avatar
PassionFords Creator
May sound daft, but you did leave her nailed till gone 4000rpm didnt you?
If your used to a T3 or similar, you could be forgiven for thinking a T4 doesnt even work.
Old Jul 22, 2007 | 11:47 PM
4x4 ste's Avatar
4x4 ste
When i got my T4 from turbo tecnics it was only set to a standard rs500 setting i think around 10 psi iirc and that felt like it didnt work untill it was wound up to 36 psi by a mapper in blackpool
Steve
Old Jul 23, 2007 | 06:55 AM
Do they even work below 4000rpm ?
If you did not tell them what psi to set it to, they most likely will have set it very low.
Old Jul 23, 2007 | 10:15 AM
dox's Avatar
dox
ive never driven a car with a t4 but as tabetha said, a turbo of that size
i wouldnt expect to come onto boost till 4000rpm+
may even have a faulty actuator that letting the wastegate open
and bleeding of exhaust gases before she spools.
its not recommended but take the vacum line of the actuator go for a thrash an see if it spools up, but keep an eye on ya boost gauge at the sametime.
Matt Baxter
Sep 16, 2015 08:30 PM
mint_s2
Sep 2, 2015 08:58 AM
gchristophi
Aug 31, 2015 10:36 PM
CrOwSoN15
18
Aug 22, 2015 10:24 PM
Escortdriver1
Jul 31, 2015 02:36 PM
