Kangarooing Escort MK4 EFI CVH
Old Jul 16, 2007 | 10:18 AM
jedi0_3's Avatar
jedi0_3
Default Kangarooing Escort MK4 EFI CVH
Morning all.
I have the above problem at low revs, kangaroo's a bit at slow speeds, sometimes need to dip clutch to stop it.
Fine everywhere else in rev range.
Will try changing sensors but could it be Throttle position sensor at fault?
Thanks
Old Jul 16, 2007 | 12:48 PM
SafeChav's Avatar
SafeChav
TPS is prone to wear, also might be worth trying another speed sensor.
Old Jul 17, 2007 | 10:58 AM
jedi0_3's Avatar
jedi0_3
Mine does not have the idle control valve on the top of the air box lid.
Is the speed sensor the round box of tricks on the speedo cable where it fits into the gearbox?
Also any ideas where to get said throttle position sensor-just tried Fords-only have one on computer for 1993 onwards at Ł75
Old Jul 17, 2007 | 12:49 PM
SafeChav's Avatar
SafeChav
Your car will have an ISCV.......only the early weber ones are on the airbox and they are fucking shit anyway
yes it is
I have TPS, and im also noticing where you are from (good choice)
Old Jul 17, 2007 | 01:04 PM
jedi0_3's Avatar
jedi0_3
No idea where it is then, I have TPS, MAP, ACT, ECT, COPOT and EEC IV, Haynes manual only shows ISCV on top of the airbox!
Any other options apart from Fords for obtaining replacement sensors?
Thanks for all of your help mate.
Old Jul 17, 2007 | 02:12 PM
jedi0_3's Avatar
jedi0_3
Now found the ISCV, cylinder mounted onto the side of the EFI inlet, not sure that it can be taken apart and cleaned though.
Let me know on the TPS Safe Chav.
Anyone got EFI Speed sensor/speedo cable?
Thanks again all
P.S. Do any Passionford members meet in Bristol/Glos Area?
Old Jul 17, 2007 | 04:49 PM
SafeChav's Avatar
SafeChav
I PM'd you back mate.
I've got a speed sensor also
No meets as such, theres Cheltenham Cruise which is, errrrrrrm, "interesting"
Me and rsdaz off here pop down there sometimes when the cunt isn't moaning about the weather conditions
Old Jul 17, 2007 | 04:58 PM
jedi0_3's Avatar
jedi0_3
Will pm you Safe Chav.
JK12
33
Apr 26, 2021 12:09 PM
FlashRS
Sep 14, 2015 12:36 PM
s1turboman
Aug 29, 2015 04:27 PM
Vincereese
Aug 18, 2015 03:57 PM
A.t.p
Aug 15, 2015 11:37 AM
