Brakecaliper dustseals
Old Jul 12, 2007 | 06:15 PM
JanDK's Avatar
JanDK
Default Brakecaliper dustseals
Hi... I am thinking of uprating my brakes and I am offered a set of bigger race calipers.. but without dustseals.. HOW important is it that there are dustseals on my EscCos ??
Old Jul 12, 2007 | 06:50 PM
Not that important if you take them off and clean them all up really well once a month.
Will most likely still give trouble eventually though.
Old Jul 13, 2007 | 08:19 AM
JanDK's Avatar
JanDK
ehhmm.. dont think that will be a good idea then!
Thanks Tabetha
Old Jul 13, 2007 | 02:30 PM
SafeChav's Avatar
SafeChav
Are they Puma calipers by any chance?
Old Jul 14, 2007 | 11:50 AM
JanDK's Avatar
JanDK
PUMA calipers?? no AP´s ...
Old Jul 14, 2007 | 05:13 PM
SafeChav's Avatar
SafeChav
Puma calipers are 6 pots i think and don't have any dust seals.
Was just wondering
Old Jul 20, 2007 | 11:14 AM
Jonzy's Avatar
Jonzy
I run tarox calipers without dustseals. Sometime get the odd sticky piston if I haven't cleaned the car for a few weeks. Usually just spray some wheel cleaned around the pistons and wash it off with the wheels, seems to keep em free.
Old Jul 20, 2007 | 06:18 PM
NUTS RuS's Avatar
NUTS RuS
Dust seals are actually better called corrosion seals
If the caliper is aluminium and the piston is stainless steel then there is nothing to corrode so the seal isnt needed.
They came about due to the mass production of mild steel chromed pistons in cast iron calipers which after a while begin to rust and will stick. This seal helped to prevent the rust forming.
What are the pistons made of ?
If your brakes are that dusty that you need to clean them every month then your on the wrong pad compound and could do with changing to a lower dust emitting one
Old Jul 21, 2007 | 05:52 AM
JanDK's Avatar
JanDK
Ahh.. corrosionseal. Nice to know.. may be looking in to "no dust seal" calipers anyway
2224v
May 25, 2009 05:15 PM
2224v
May 20, 2009 06:21 AM
Spotmatic
Ford Escort RS Cosworth
Dec 5, 2007 05:15 PM
Cam
Mar 8, 2006 11:50 PM
craig2016
15
Feb 2, 2006 09:00 AM
