help plse st 24
wife just went to go to shops cannot select gear.the clutch is fine and not slipping e.t.c. .if u turn the engine off u can select any gear no probs.but when ignition is on cannot get any gear.if you start the car with it already in gear it drives itself i.e. as if the lutch is out ,but its not.any ideas.
jcanrsescort
Feb 1, 2012 08:06 PM
