Garrett T3 problem
Old Jul 11, 2007 | 08:43 PM
jonboy's Avatar
jonboy
Old Git
Default Garrett T3 problem
Bought a recon T3 via fleabay recently, it had obviously never been near a car as it looked spotless...
Thing is, I put it on a brand new ERST setup in the Fiesta Pop Plus, and it boosted for about 15seconds. Then all I got was a whining noise.
It looked brand spanky new when I got it, and it had NO play whatsoever, so I believe it to have been a pukka rebuild -- it still has no play in any direction.
Where is the boost going?
It has got me stumped. Is it worth a rebuild kit?
Jonboy
Old Jul 11, 2007 | 09:18 PM
rinus_2005's Avatar
rinus_2005
you don't have any boost? Did you check you boosthoses,incooler & plenum for signs of leak?
Old Jul 11, 2007 | 09:20 PM
jonboy's Avatar
jonboy
Old Git
Yup, no leaks, stuck an old T3 on there, and it boosted fine.
Very very puzzled.
Old Jul 11, 2007 | 09:27 PM
mechanic28's Avatar
mechanic28
is the exhaust turbine spinning when u spin the the turbo from the inlet side
Old Jul 11, 2007 | 09:31 PM
jonboy's Avatar
jonboy
Old Git
It all spins fine together. It looks perfect apart from the the fact it doesn't boost.
Old Jul 11, 2007 | 09:50 PM
mechanic28's Avatar
mechanic28
have u tried swapping over the actuators?
Old Jul 11, 2007 | 10:20 PM
jonboy's Avatar
jonboy
Old Git
Yup fella, swapped everything over, like for like.
But I will give it one last chance.
Will try it again in my present 2.1 ZVH setup
Will keep you posted. But I don't hold much hope!
Old Jul 12, 2007 | 11:43 AM
SafeChav's Avatar
SafeChav
So you know the shaft isn't snapped?
And you've swapped the actuators.
What about the wastegate penny? Are you using the same elbow on both turbos? Did it produce from the exhaust smoke at all?
Old Jul 16, 2007 | 08:49 PM
105epwr's Avatar
105epwr
check for any swarf etc etc in thr waste gate valve
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
