knackered injector
Old Jul 9, 2007 | 12:03 AM
Reid's Avatar
Reid
Default knackered injector
well got my immobiliser probs sorted on my mk6 escort (1,8) but turns out the engines only firing on 3 cylinders. im thinking its the injector thats knackered - when i unplug it there no difference in the running of the car.
how do i go about sorting it? is it just a matter of changing the injector or another way? if so would the 1.6 injectors do it?
Old Jul 9, 2007 | 05:20 AM
See if the plug is WET.
NO spark will also cause this but still be fuelling.
It would be ok to use temporarily a 1.6 injector to see if it that though.
I don't know the flow rates so would not like to say it is the same injector, as I don't know, but will do no harm idling to try it out.
Old Jul 9, 2007 | 05:22 PM
Alvyn's Avatar
Alvyn
why dont you change the injector with one of the others to eliminate it also as the problem?
Old Jul 9, 2007 | 05:33 PM
Reid's Avatar
Reid
sorted it today, changed the fuel rail over with a spare one i had off an old engine.
cheers for the help
mk3ste
Oct 17, 2021 10:09 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
