Problems with volts from the battery
Old Jul 2, 2007 | 08:12 PM
Darron1823's Avatar
Darron1823
Default Problems with volts from the battery
Hi there, Im currently trying to install a Megasquirt ECU in my MK 5 Escort Cab. We've been having a problem with the voltage from the battery when cranking, instead of the regular 12vs im only getting 9vs. Im getting this with both the standard ECU and the MS. Iv been told that the MS needs the full 12vs to run the injectors hence no luck starting it so far, where as the standard ECU doesnt need the 12vs to turn over?
Any clues any1?
Also; Can any1 make an eeciv connector to msv3 and also make an adaptor plug and bulk if so how much?
Darron
Old Jul 3, 2007 | 04:33 AM
Megasquirt will work perfectly with the voltage you have at cranking as ALL batteries will drop under load like this.
Old Jul 3, 2007 | 08:59 AM
sailorbob's Avatar
sailorbob
The problem will not be down to battery voltage whilst cranking. I don't know what version of software your MS uses but the one I've looked through has voltage compensation for the injectors allowing for a range of 7.2 to 19.2 volts. I cannot imagine any ecu not compensating for variance in battery voltage otherwise the ecu could never deliver it's fuel accurately.
If the injectors aren't firing, have you checked to see if the MS is getting the crank position signal?
Old Jul 5, 2007 | 04:45 PM
Darron1823's Avatar
Darron1823
Cheers guys,
Its my m8 who is more technical than me. He built an Escort 2.1L turbo'd zetec on megasquirt n he cant figure out wats wrong with it.
What type of wire do you suggest to make the loom as im running direct coil?
Darron
Flatlinedan
Sep 18, 2015 12:41 PM
tib2220
Sep 14, 2015 12:33 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
cameron2
Sep 6, 2015 10:40 AM
