fuel pressure on cosworth
Old 01-07-2007 | 08:05 PM
raggey's Avatar
raggey
Default fuel pressure on cosworth
Chaps
Could any one help me, I have put a pressure gauge on my fuel line of my cossy engine and the pressure is 2.8 bar is this ok, I have been told it should be around 3.5 bar. Also I was told that you can adjust the regulator. The regulator is new and a normal cosworth webber one, is this correct and if so how do I do it.
Paul.
Old 02-07-2007 | 08:12 AM
Fuel pressure should be 2.7 to 3.3 BAR at IDLE.
Without engine running but ignition on it should be 3.2 to 3.8 BAR.
DON'T go adjusting unless going to a R/R for check, but 2.8 is fine at idle.
Old 04-07-2007 | 08:19 PM
rinus_2005's Avatar
rinus_2005
when adjusting is needed, it has to be 3bar with the vacuumline off or on?
(it's about 0,5bar difference)
Prickly_buzz
25-08-2015 12:33 PM
Stu @ M Developments
41
21-08-2015 07:47 AM
Bailes1992
16-08-2015 08:14 PM
14-08-2015 08:29 AM
Zoggon
10-08-2015 11:39 AM
