escort high temp!!!!
Old Jun 29, 2007 | 12:09 PM
nobbycossie's Avatar
nobbycossie
Default escort high temp!!!!
My wife has a `97 1.6 escort chicane . The fan isn`t kicking in and water temp. gets very high . I have checked fuses and stuff and all looks good. Am I assuming right that it could be thermostat? If so is this located just to the right of the oil filler cap (as you look at engine from the front) on a big water pipe coming from top of radiator?
Any help would be greatly appreciated
cheeRS
Old Jun 29, 2007 | 12:28 PM
rs_cabby's Avatar
rs_cabby
if the fan's not kicking in, it sounds like the temp switch for the fan is knackered, try bridging the contacts in the plug to make the fan run constant and see if it still overheats.
Old Jun 29, 2007 | 12:32 PM
As said if fan still does not work try 12v direct to fan to see if motor seized if noit out with the metre!!
Old Jun 29, 2007 | 01:34 PM
nobbycossie
just changed sensor and has made no differance, will get multi meter on plug for fan later and see if fan itself is knackered or as you say wire it up directly.
What do you mean by bridge contacts? as surely this will just short it out?
There are only 2 contacts in the plug!!!!
Old Jun 29, 2007 | 01:48 PM
rs_cabby's Avatar
rs_cabby
basically the temp switch is exactly that, a switch, when the switch picks up the high temp it creates a circuit between the 2 wires going to it.
i think both wires are an earth basically and the fan cannot work unless a circuit is made between the 2.
hope that helps mate
Old Jun 29, 2007 | 02:10 PM
nobbycossie
cheers will try later
Old Jun 29, 2007 | 02:29 PM
It will work as described bridge the contacts, if ok.
Old Jun 30, 2007 | 08:40 AM
nobbycossie
Bridged contacts and didn`t work guess and wire up fan direct and see what happens
Vincereese
Jun 1, 2023 09:14 AM
Derek Burleigh
Sep 16, 2015 06:27 PM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
