coolant sensor
Old Jun 22, 2007 | 09:05 PM
tob4x4's Avatar
tob4x4
Default coolant sensor
lol once again on here after help, can anyone explain the fitting instructions for the coolant sensor that operates the temp gauge, i have the part just need to fit thanks
Old Jun 22, 2007 | 10:44 PM
messcortmk6's Avatar
messcortmk6
the coolant temperature sensor should scew straight into the cylinder head.
can you please explain fuly what the problem is then i can help
Old Jun 23, 2007 | 06:37 AM
As said, just pull off connector on existing one, then unscrew it, screw new one in put connector on.
If you have the new one to hand you can simply put your finger over the hole to stop the water flow, won't be a lot anyway if cap is on expansion tank, then screw new one in.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
