Oil blowing out of the breather
Old 22-06-2007, 03:43 PM
benib
benib's Avatar
Default Oil blowing out of the breather
Hi Can anyone tell me why my 1.6 zetec is blowing oil out of the breather which is on the cam cover it doesnt smoke it seems to be a little down on power it will only pull 100 when it used to do 120 easy, could this be the head gasket blown between a cylinder and a oil gallery also i am loosing a bit of water i have to top it up every couple of weeks
Cheers Ben
Old 22-06-2007, 05:39 PM
I would go with your suspicion, ie headgasket.
Old 23-06-2007, 12:35 PM
benib
benib's Avatar
i think ill change the gasket and take the head in to be checked see weither i have drooped stem seal im gonna pressure test it at some point see if there is any irregularitys in cylinder pressure.it is alao due a cam belt the poor things done 140,000 miles lol but saying that my mums automatic escort did 200,000 before the gearbox fucked up zetecs are a brilliant engine
Old 23-06-2007, 05:09 PM
benib
benib's Avatar
where is the best place on the internet to get the bits to do it ie gasket set timming belt, locker kit, tensioners and water pump Cheers Ben
Old 24-06-2007, 02:25 PM
jayRS
jayRS's Avatar
go to a motor factors mate.
in fact fuck the engine off and fit a 2 litre
do a compression test with no plugs in, this will tell ya if you have problems.
the breaher system could be proper blocked up as no one norm ever bothers to change the breather filter
Old 24-06-2007, 11:33 PM
SafeChav
SafeChav's Avatar
excessive blow by i would say! If the gasket was gone you'd probably being seeing symptoms like the coolant and oil mixing!
Compression test it
Whats this about getting the head checked to see if you have dropped a stem seal
Old 26-06-2007, 02:09 PM
benib
benib's Avatar
i ment to say see if its dropped a valve and get the stem seals changed its running like a bag of shit think ill get another engine maybe a 1.8 out of another escort cant be botherd fuckin about with fittin 2 litre as my car is a german built model i think im gonna have problems as the loom and ecu is different
Old 26-06-2007, 05:42 PM
SafeChav
SafeChav's Avatar
When you say its german built?
Why not do a compression test?!
Old 29-06-2007, 04:48 PM
benib
benib's Avatar
I ure tested it and it was down on 3 and 2 so its blowin across the cylinders dunno about the german thing but i had to change the steering rack and mine is completely different to the normal ones i asked why and they had a look at my car and told me it was a german built model?
Old 29-06-2007, 06:00 PM
SafeChav
SafeChav's Avatar
Old 29-06-2007, 06:09 PM
jayRS
jayRS's Avatar
yeah seems head gasket could be naffed then.
not heard about this german built thing, as most fords were made there or in spain
Old 29-06-2007, 06:16 PM
SafeChav
SafeChav's Avatar
Just sounds like a poor excuse from someone who can't fix it and/or doesnt know what parts it needs to me
Old 29-06-2007, 11:02 PM
benib
benib's Avatar
i dunno mate he semed to know his stuff and the steering rack was completely different my car is a 96 1.6 escort if i get a 1.8 escort lump will i be able to drop it straight in my car and change the ecu the engine aint a problem for me but do i need to use the keys from the 1.8 cos the keys are coded to the ecu thats the only thing im worried about i got visions of gettin the engine in and goin to fire it up and nothin happenin lol
i gotta do the cam belt head gasket and valve stems so i might aswell put another engine in.
Old 29-06-2007, 11:20 PM
SafeChav
SafeChav's Avatar
The engine will drop straight in but im not 100% on the ECU situation, this all falls back to whether the PATS & EDIS are internal on the ECU or not
Old 30-06-2007, 09:51 AM
benib
benib's Avatar
is there a way of checking the ecu code to find out about pats i got an alarm if it helps its weird tho its only ever gone off twice ones when i locked it with a door open and ones i opened the boot with the key and the alarm went off wen i shut it. but shurely if i get a 1.8 ecu with the red key i can program it to accept my original key, but then if i get too many problems with the ecu can i leave my 1.6 ecu in and get it chipped surely with the chip it will run okay
Old 30-06-2007, 10:01 AM
benib
benib's Avatar
I just used a VIN decoader and it appears my car was built at hailwood uk, in september 1995 the bloke at the ford garage was obviously wrong lol but the steering rack is strange tho the pipes are threaded into the rack where normally the pipes are on a block which bolts to the rack does any one now how to tell what ecu i got and what one i need
01-11-2015 06:53 PM
Brickhouse
14
03-10-2015 07:28 PM
DAZZER
30-09-2015 08:43 PM
Fudgey
21
30-09-2015 06:19 PM
Quick Reply: Oil blowing out of the breather
