Cossie Prop Shaft Bolts
Old Jun 14, 2007 | 04:29 PM
polly_x's Avatar
polly_x
Default Cossie Prop Shaft Bolts
Does anyone know what size these are (4x4 diff)?
Are they M10 x 1.5?
Also, where can I buy suitable high tensile bolts for propshaft application?
Ta
Old Jun 14, 2007 | 08:27 PM
cos jon's Avatar
cos jon
This place is usually pretty good mate, they don't have that size your specifing though only M10x 1.0mm or M10 x 1.25mm
I would assume for the prop you would need Grade 10,9 rather than 8,8 but they may have the size ??.
Not many places seem to be able to supply 10,9 either....
http://www.namrick.co.uk/browse.asp?PCID=9
Old Jun 15, 2007 | 06:11 AM
I don't know the size but can get all the bolts.
You do NOT want high tensile here, as you need some ductility in the bolt.
Get me the size and I'll tell you the bolt cost, which is only going to be around 15-30 p each
Old Jun 15, 2007 | 12:01 PM
polly_x's Avatar
polly_x
Do you class 10,9 as high tensile? Thats whats ford use on the diff to prop flange (although I believe its UNF thread though)
Ive got some 10,9's coming now. Thanks for the offer though tabetha much appreciated.
Old Jun 15, 2007 | 12:24 PM
10.9 is not the strongest, but if that is what it had they are obviously ok, the stronger the bolt the more brittle they become losing their ductility.
SS for example would be unsuitable for this location as it is brittle.
IainRS1700T
Sep 25, 2015 06:44 AM
focuspower
Sep 19, 2015 08:27 PM
3doorcozmess
Sep 15, 2015 06:06 PM
rsstav
Sep 7, 2015 04:43 AM
hopper350
Sep 4, 2015 12:53 AM
