just cant find reley
May 31, 2007 | 12:11 PM
is the fuel pump definately working when it should
May 31, 2007 | 12:29 PM
no im not sure just been over and had a look at that flap your on about it has a pool of water at the bottom of it, from the rain coming through the vents
like 1cm deep,i have taken the pipe of the fuel filter and turned the key fuel is coming out
May 31, 2007 | 12:36 PM
May 31, 2007 | 12:37 PM
May 31, 2007 | 12:38 PM
i also just want to say thank you for helping me with this
May 31, 2007 | 12:57 PM
okay i am sorry for this yeah just cleaned all metering unit inside everytime i press the flat down petrol goes into the bottom of the flap and forms a pool
May 31, 2007 | 01:02 PM
ahhhhhh, well done
theres one problem then
new metering head required, or a service kit.
Very common problem that
May 31, 2007 | 01:07 PM
cool know your stuff yeah
so if i get a new 1 do you think she will fire up??
May 31, 2007 | 01:08 PM
well you're losing fuel pressure because of that so its more than likely why it wont fire, the injectors are pressure operated.
Either way, it shoudn't be like that.
I expect that was fuel in the bottom though and not water like you thought
May 31, 2007 | 01:12 PM
May 31, 2007 | 01:32 PM
Jun 1, 2007 | 12:20 PM
okay went 2 see that guy the day and he dosnt have 1
is there any way i can fix my unit?(or is it 2 hard)if not then do you know where i can buy a second hand 1
Jun 1, 2007 | 01:15 PM
you can fix them yea, the seals inside go.
Apparently Stu @ MSD off here sells them, speak to him hes a good bloke
Jun 1, 2007 | 01:38 PM
okay cool will do thanks for that
do you think it will be ok for me to do yeah(a novice)
Jun 1, 2007 | 01:45 PM
i've not done it myself but from what i've seen its pretty easy.
I think its an O ring inside that perishes, should be easy enough.
Stu will be able to tell you more specifically tho, give him a call and tell him i pointed you in his direction
Jun 1, 2007 | 05:02 PM
morrison
where in scotland are you my mate breaks them let me know if your still looking
Jun 1, 2007 | 08:15 PM
hi m8 i am in inverness area
yeah im still looking
Jun 1, 2007 | 08:16 PM
okay thanks safechav how do i get in contact wif him?
Jun 1, 2007 | 10:19 PM
mk3ste
Oct 17, 2021 10:09 AM
boeb
Jan 9, 2020 05:11 AM
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
2wdsaph ben
18
Oct 2, 2015 05:18 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
