slow transit swb 2.5 d
Old May 1, 2007 | 03:25 PM
ADSRST's Avatar
ADSRST
Default slow transit swb 2.5 d
please help i have a transit on a m plate and it is so slow and really bad on fuel, at the moment its doing about 100 miles to £20 and its so slow.
any ideas please
cheers adam
Old May 1, 2007 | 03:53 PM
Tweak the pump!!
I did this on my escort diesel and gained mpg and speed, as it developed a lot more torque then.
Old May 1, 2007 | 05:18 PM
cossiegreg1's Avatar
cossiegreg1
does it have a cat.if so make sure it hasnt collapsed causing a blockage,also has it been serviced ie air filter,fuel filter?
Old May 1, 2007 | 05:48 PM
MrMPuk's Avatar
MrMPuk
100 miles to £20 sounds about right to me, and when you say slow what are we talking?
Old May 1, 2007 | 07:00 PM
DROPTOP's Avatar
DROPTOP
empty the back .
mine does a bit more than 25 / £5 and its always full / gets full throttle rallied everywhere.
tab , stick us up some step by step tweak instructions
Old May 1, 2007 | 08:42 PM
ADSRST's Avatar
ADSRST
cheers people ill be tweaking the pump in the morning found this
http://www.fordtransit.org/forum/viewtopic.php?t=3968
Old May 1, 2007 | 08:47 PM
I can't as you won't inform your insurance company you naughty boy!!!
Old May 1, 2007 | 09:34 PM
DROPTOP's Avatar
DROPTOP
go on . insurance is void anyway ! frosties packet MOT isnt recognised by any insurers as far as i know
Old May 2, 2007 | 04:50 AM
It is a little more difficult on these as have never done one, well not a newer one anyway!!
It is only a case of turning up the governor pressure, usually through a hole in the side of the pump body, but need to know precisely what engine and PUMP as no doubt there are different ones.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
Brickhouse
Sep 20, 2015 11:47 AM
