xr3i efi misfire
my cars is misfirein have replaced the
plugs , leads ,
any idea wat could be causeing it to misfire
any help will be greatful
cars now been off the road for a month please need help with gettin it to run as it should
thanks dan
plugs , leads ,
thanks dan
As it's regular most likely a problem only on one cylinder.
Leave it running and pulleach plug lead in turn to see which one.
If this makes no difference then try the disconnecting each injector inturn so as to identify dodgy cylinder, then do a compy test to determine what it is.
07-10-2015 12:56 PM
