iscv valve
Old Apr 22, 2007 | 11:19 AM
2wdsaph ben's Avatar
2wdsaph ben
Default iscv valve
how is the best way to clean it. mine flutters the revs up and down on cold.
been told that carbrutter cleaner is best.i havent got any of that is brake cleaner the same sort of stuff or can i use anthing else like wd40.?
what do i need to do, unscrew it of engine and spay inside?
cheers
ben
Old Apr 22, 2007 | 12:49 PM
Don't dismantle the actual valve, just take off car and then use a small screwdriver to push centre plunger down GENTLY, as it is this bit that sticks, and then you can really spray where it matters.
USE proper carb cleaner though and spray with silicone spray afterwards as this helps to resist build up of crap again.
I use DASH DANDY to spray after cleaning as it has a lot of silicone in it.
Old Apr 23, 2007 | 12:17 AM
SafeChav's Avatar
SafeChav
Should be fine with brake cleaner IMO its all similar stuff!
You only want it to degrease and remove all the crap
Old Apr 23, 2007 | 06:04 PM
2wdsaph ben
thanks for the advice. do that at weekend. been annoying me for ages!
DixieTheKid
11
Jun 6, 2020 11:20 AM
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
RS-Rikki
Sep 21, 2015 07:27 AM
