1.6cvh vs 1.8 zvh power
Old 15-04-2007 | 09:53 AM
RS 5tu's Avatar
RS 5tu
Default 1.6cvh vs 1.8 zvh power
Just wondering my cab has a 1.6cvh rst engine and a chip and a -31 just wanted to know how much more power would i have got if i went zvh instead if cvh.
Cheers for any help.
Old 15-04-2007 | 10:24 AM
DazC's Avatar
DazC
Only as much as the cylinder head/cam/turbo will flow. If you're just going to run the exact same set up top end and management (basically everything the same but a different bottom end, then you will produce roughly the same power. The only benefit will be that the extra gasses the 1800 can shift at low/off boost RPM will just help to spool the turbo up a little quicker.
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
Daniel Howard
Ford Classics & Vintage
03-10-2015 10:44 PM
phil51
Ford Focus Diesel
02-10-2015 01:00 PM
Iain Mac
30-09-2015 09:39 PM
dojj
29-09-2015 10:32 PM
Quick Reply: 1.6cvh vs 1.8 zvh power
