Magic Missing Fuel Pump Volt
Old Jan 8, 2004 | 07:10 PM
Default Magic Missing Fuel Pump Volt
When I check the voltage to my fuel pump wire - not connected to the pump its around 12.40 volts - fine!
When I check the voltage to my fuel pump when its connected and working its 10.36 volts - not so good!
Wheres the almost 2 volts going and does this mean my pump is focked! Id measure the amps but I cant work me meter
Cheers in advance
Old Jan 8, 2004 | 07:28 PM
bttt
Old Jan 8, 2004 | 07:33 PM
Mr Bump's Avatar
Mr Bump
Somethings definately not right.
Check all the cables, especially the earth points.
Could need just a clean up of the connections or maybe a complete rewire. It may even be a tired pump drawing more current than the cable can supply, so the volts drop.
Ben
Old Jan 8, 2004 | 07:38 PM
PJay's Avatar
PJay
Knackered wiring or a bad earth, just run new wiring for it using the old wiring to activate a relay to switch it.
PJay
Old Jan 8, 2004 | 08:24 PM
Thats what I was thinking mate because the wire is of good quaility and guage, its also quite new - like a year old!
So is that perfectly possible or likely then?
Dave.
Old Jan 8, 2004 | 08:27 PM
PJay's Avatar
PJay
If the pump was drawing more current than the cable could supply the cable would melt
Old Jan 8, 2004 | 08:44 PM
The volts must be dropping for some reason!
Old Jan 8, 2004 | 08:46 PM
Mr Bump's Avatar
Mr Bump
Its either high current draw, faulty pump or a wiring problem.
The easiest to test is by we doing all the earth points around the pump/pump craddle/chassis.
Ben
Old Jan 8, 2004 | 08:48 PM
The car wont run properly either so maybe it is a faulty pump?
Cheers for help.
Old Jan 8, 2004 | 09:07 PM
PJay's Avatar
PJay
It is possible the pump is faulty, have you checked the fuel pressure as suggested the other day?
Old Jan 8, 2004 | 09:10 PM
Yeah and it goes to 5 bar when first primed!
Then when the car is running it sits around 3!
Sound any good?
Old Jan 8, 2004 | 09:15 PM
PJay's Avatar
PJay
Was this measured at the rail? I'm not sure what fuel pressur the frst runs TBH but i'm sure someone will
Old Jan 27, 2004 | 03:30 PM
Chick's Avatar
Chick
Those pressures sound OK to me, not sure what specifically the FRST fuel pressure is meant to be but my mate's mk2 rally car which runs 2x 45 DCOE's goes to about 4.5 bar when primed and then 2.75 when running. When you measured this pressure was the car running OK? You want to know what the prerssure is when the car isn't running OK to relate the running problem to the fuel pump. HTH
Old Jan 27, 2004 | 04:18 PM
Dave Henshall's Avatar
Dave Henshall
when the pump is running, the connections accrom the pump, will drop voltage slightly because it is running, this is normal.
Old Jan 27, 2004 | 05:48 PM
nthorpey's Avatar
nthorpey
Inside the tank on the frst there is a small black box, which is some sort of choke to stop electrical noise. This actually melted in my old car Check this aswell and try and bypass it see if this cures any probs
Old Jan 27, 2004 | 05:50 PM
nthorpey's Avatar
nthorpey
this bit here
JK12
33
Apr 26, 2021 12:09 PM
DixieTheKid
11
Jun 6, 2020 11:20 AM
155lee
Oct 27, 2015 04:55 AM
15
Oct 7, 2015 03:43 PM
Cossiesteve
Ford Escort RS Cosworth
Sep 17, 2015 12:37 PM
