Cossy Failed test on emissions
Old Mar 29, 2007 | 06:20 PM
wayneRST's Avatar
wayneRST
Default Cossy Failed test on emissions
Took my standard 3 door cossy for its first MOT for a good few years today, and its basically running really rich. I can clean the black sooty plugs and it will be fine for a while and then soot up again and start misfiring.
I got the MOT tester to stick it on the machine and it was registering 9.9 somethings at idle, whereas it should be around 3.
I'm hoping it is something simple as the car is not taxed or tested so I cant take it anywhere to get it sorted. The car has only done 2000 miles in the last 14 years so the problem could be related to the lack of use.
Thanks
Old Mar 29, 2007 | 06:40 PM
Have u tried adjusting the mixture with the mixture screw on the engine ecu.Put the car on an emissions tester n turn the screw till the emissions get back 2 where they sud be.
Old Mar 30, 2007 | 10:12 AM
jon@work's Avatar
jon@work
I wouldn't do that IF you know that the car was running well enough previously to pass an MOT before the car was laid up and nothing has been changed since.
Sounds like it could be either the water temp sensor at the rear passenger side of the head, or the wiring to it.
TPM961
Jan 15, 2018 10:50 AM
Fiddy
21
Sep 29, 2015 06:10 PM
SMILER258
Sep 28, 2015 09:04 AM
Russ Payne
Sep 25, 2015 08:29 PM
Eigdoog
48
Sep 19, 2015 11:03 AM
