zetec turbo how much boost?
Old Sep 13, 2004 | 04:36 PM
mrviper's Avatar
mrviper
Default zetec turbo how much boost?
hello all
i have acumilated all the parts to do a 2.0 zetec turbo conversion with a decomp plate being orderd from from the guy at http://www.zetec-turbo.co.uk/
im using a std t3 turbo and pace intercooler from an escort rs turbo and omex management
the standard rods and pistons will be retained to cut costs.
basicly im asking what boost should be used with this sort of setup
hopfuly some one here who has done it before will be able to help me out with my question
cheers Mr V
Old Sep 13, 2004 | 04:40 PM
wimwerf's Avatar
wimwerf
depends of the compression. and what t-3 do you have. a standard t-3 of an RST cant do much boost as one of the saph cos 4wd.
cheers
Old Sep 13, 2004 | 04:50 PM
mrviper's Avatar
mrviper
its made to do 8.1:1 ratieo
im just trying to find out what results i will get with my kit
i dont think i need cosie boost in a fiesta tho
Old Sep 13, 2004 | 07:09 PM
wimwerf's Avatar
wimwerf
a saph4wd t-3 is a better option.
cheers
Old Sep 13, 2004 | 10:55 PM
mrviper's Avatar
mrviper
whats different with the saph cos turbocharger ?
i thought there simular but with a -31 actuator
Old Sep 14, 2004 | 06:08 AM
wimwerf's Avatar
wimwerf
from a standard form. the t-3 from a saph 4wd is the biggest. it can flow more air then the t-3 of the saph2wd.
the saph cos turbocharger has a bigger ex.house and a bigger comperssorwheel. and the inlet of the comperssionhouse could be bigger. but for the conversion you are building, i think youre better of with the saph4wd t-3 then with the rst t-3 which is to small.
cheers
Old Sep 14, 2004 | 07:46 AM
JesseT's Avatar
JesseT
Just to clear things up:
____________RST S1/S2_____Cossie 2wd____Cossie 4wd
comp. trim._______40 ?____________55___________60
ex. housing_______.36____________.48___________.48
Same on all three:
compressor outer diameter
turbine wheel
Old Sep 14, 2004 | 10:22 AM
wimwerf's Avatar
wimwerf
Same on all three:
turbine wheel
Old Sep 14, 2004 | 11:43 AM
scooby8272's Avatar
scooby8272
I have been told on average a Bar of boost with a decom plate
Old Sep 14, 2004 | 02:50 PM
Jon ERST S2's Avatar
Jon ERST S2
I wouldn't want to run any more than a bar and only on the smaller RST turbo. Decomp plates are never a good idea. They do work for some people but I wouldn't be happy driving a car with one myself. Better to do it properly or not do it at all IMO.
Old Sep 15, 2004 | 08:01 PM
b13nde's Avatar
b13nde
i would say 18 psi at least you can run a 1.6 rst with a comp rate of 8.2.1 and more in some cases just do it you only live once
robnock
21
May 13, 2019 05:29 PM
gchristophi
Aug 31, 2015 10:36 PM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
