s2 rs turbo running?????????
Old Mar 19, 2007 | 11:34 AM
ianshad6's Avatar
ianshad6
Default s2 rs turbo running?????????
can anyone help?
s2 rs starts some times and runs revs fine but if you let off the throttle it stalls it self and dies
then we have to turn it over 25-20 times and then starts its a bit smokey but it revs clean but just wont idel??
the only thing it has is a chip?
and it back fires too?
can anyone help as its my daliy car know so could do with the info as why its been a pain?
any help pls ian
Old Mar 19, 2007 | 03:05 PM
SafeChav's Avatar
SafeChav
Sounds like it could be a few things if its back firing aswell.
Check for air leaks, and also i'd check the cam belt timing and so forth. Dont really know what else to suggest its not a lot of info to work with
Old Mar 21, 2007 | 03:42 PM
ianshad6's Avatar
ianshad6
well we put the belt on and its spot on?
becouse we can get it to ideal we can set the ing timing up?as for air leaks it all seems ok as we have cheaked every where?
will the chip be a prob?
Old Mar 21, 2007 | 04:55 PM
SafeChav's Avatar
SafeChav
Ignition timing aswell.
I doubt its the chip. Could be a knackered pump possibly!
Old Mar 21, 2007 | 05:38 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
metering head!
Old Mar 23, 2007 | 09:27 AM
ianshad6's Avatar
ianshad6
dose the ingtion side need to be set on 0
do you alter the idle on the screw on the throttle cable or the pot?
Old Mar 23, 2007 | 03:31 PM
SafeChav's Avatar
SafeChav
Ignition side?
POT........on a Series 2
Old Mar 26, 2007 | 04:25 PM
ianshad6's Avatar
ianshad6
sorry iment body?
on the dizzy on a timing strobe needs to bet set at 0?
will the idle make a diifence is what im saying?
Old Mar 26, 2007 | 05:01 PM
SafeChav's Avatar
SafeChav
if you set a timing gun to zero and then adjust the timing so the bottom pulley mark times up you will be running the ignition firing ATDC
Old Mar 27, 2007 | 09:55 AM
ianshad6's Avatar
ianshad6
so what are you saying before or after?TDC
Old Mar 27, 2007 | 01:29 PM
SafeChav's Avatar
SafeChav
Well if you set the timing gun to the correct timing, you then line up the bottom pulley mark with the timing marks on the cam cover and thats it set.
I dont think theres an engine in the world that runs its timing after TDC
big_Rad
Sep 15, 2017 09:36 AM
Matt Baxter
Sep 16, 2015 08:30 PM
IAN RS2k
Aug 18, 2015 07:51 PM
Churtz
15
Aug 13, 2015 06:40 PM
turbobill
Aug 9, 2015 05:21 PM
