problem with s1
Old Mar 18, 2007 | 11:31 PM
mk3cab's Avatar
mk3cab
Default problem with s1
hi there i have a prolem with my s1 sometimes when i start it, it will run fine other times it will sound like it running on 3 cylinders and cuts out very unpredictable, could it be an ecu problem? censors? bad earths? any help would be great. its had new leads, plugs,dizzy cap,rotor arm,coil thaks matt
Old Mar 19, 2007 | 07:05 PM
mk3cab's Avatar
mk3cab
now doing it all the time could it be an over fueling problem? could over fueling make it run this bad?
Old Mar 20, 2007 | 08:59 PM
Alvyn's Avatar
Alvyn
more than likely to be the metering unit!
Old Mar 20, 2007 | 09:54 PM
SafeChav's Avatar
SafeChav
Does it do it any specific time?
I.E when cold?
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
