rs turbo pistons
Old Mar 18, 2007 | 09:39 PM
gasants's Avatar
gasants
Default rs turbo pistons
hi can any body tell me the amount you can skim off the top off the standard mahl pistons and what the comp ratio will be?
if the comp ratio was set at 8to 1 how much boost (psi) will the pistons take before i will have to change them for after market ones.
cheers
Old Mar 19, 2007 | 11:46 AM
JesseT's Avatar
JesseT
The standard pistons have around 7mm of material on the crown. Removing 1mm is no issue at all. It's a different thing if you need to. The basic pistons are surprisingly good. I've run ~30psi with the standard bottom end, including the compression ratio. Mostly I would be worried for the conrods which are known to fail when abused.
Old Mar 22, 2007 | 11:52 PM
LSD's Avatar
LSD
When I built mine, I used 1.0mm oversized mahl pistons and then under instruction from Ahmed had the crown skimmed so it ended up 5mm thick, couldnt tell you what the comp ratio was though sorry, but can tell you it went like a stink!
Old Mar 24, 2007 | 07:40 AM
gasants's Avatar
gasants
Default pistons
cheers for the sensible info!
JK12
33
Apr 26, 2021 12:09 PM
big_Rad
Sep 15, 2017 09:36 AM
Matt Baxter
Sep 16, 2015 08:30 PM
kevin36
Sep 2, 2015 06:24 PM
rsturbo27
Sep 1, 2015 09:54 PM
