Dump valve position
Old Sep 12, 2004 | 08:10 PM
M2YLE's Avatar
M2YLE
Default Dump valve position
The take off from my dumpvalve is spliced into the same pipes as the ECU uses
I have been told that this can cause "spiking" of the ECU. Is this correct and will it cure this and still function correctly if I simply splice into the pipe at the other side of the throttle body?
Old Oct 15, 2004 | 10:07 PM
blaazer2's Avatar
blaazer2
not heard of spiking by a dump valve as this is usually associated with electricity,the pipe needs to go in between the cylinder head and the throttle butterfly,not between the turbo and the butterfly as when you let off the throttle the dump valve pipe becomes vacuum instead of pressure thus releasing the pressure on the dump valve piston/diaphram, that is when the excess boost is released psssssssst it should be ok where it is
Old Oct 16, 2004 | 11:11 AM
Stu @ M Developments's Avatar
PassionFords Creator
If your dump valve ever leaks, as well as getting no dumping sound, you will also melt the engine as teh ecu will not see the pressure and hence, will not retard the spark, leading to pinking and destroyed pistons. If you must have one, Its far better off fitted to teh other side leaving the ecu pressure transducer pipe alone.
Old Oct 16, 2004 | 05:52 PM
AKRS1's Avatar
AKRS1
my previous engine blew up because the boost leaked but how dow this mess up the engine
Old Oct 16, 2004 | 06:01 PM
starturbo's Avatar
starturbo
I didnt know that stu.Thats where i had mine plugged in. I remember calling you about 9 months ago askin your advice as to why my rst kept cuttin out and you told me that if i had a dump valve to bin it and hey presto it stopped cuttin out. your too fookin clever mate.
Old Oct 16, 2004 | 11:14 PM
AKRS1's Avatar
AKRS1
Why do companies make dump valves if they leak and make rsts cut out. I have a Baileys twin piston type dump valve that works good and doesnt make the car cut out.
Old Oct 17, 2004 | 07:48 AM
starturbo's Avatar
starturbo
AKRS1,
Mine was a bailey twin piston and one day it broke and the car wouldnt idle when hot.I ripped the dump valve apart ( coz it was knackered anyway and the one of the springs had snapped.Phoned bailey but they only wanted to sell me a new valve.So now I dont have one.sod em.
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
