boost guage help!!!!
Old Mar 15, 2007 | 07:41 PM
whittyscossy's Avatar
whittyscossy
Default boost guage help!!!!
Hi all i have just brought a ford racing boost gauge, need helping install it when do i connect it to the engine. ( as you can tell im new to this and i cant find my inst ).
any pics would be great
many thanx
whitty
Old Mar 15, 2007 | 07:48 PM
SafeChav's Avatar
SafeChav
Find a small vacuum pipe AFTER the throttle plate, so on the inlet plenum or similar, and use a T piece to splice into the pipe
Old Mar 15, 2007 | 07:51 PM
whittyscossy
where is tht on a cosworth 2wd, dont really want to start cutting wrong pipes lol
Old Mar 15, 2007 | 07:57 PM
SafeChav's Avatar
SafeChav
I couldn't tell you mate thats a bit out of my league i only do old sweaty escorts
Have you got a picture of your engine bay?
Old Mar 15, 2007 | 08:07 PM
whittyscossy
ummm not on my laptop, sorry m8
Old Mar 15, 2007 | 08:54 PM
cossie0_4's Avatar
cossie0_4
the most accurate place is to cut into the pipe that goes to the map sensor and then put a t piece in the map sensor is on the passenger side inner wing about half wy and in the middle on a little bracket.there is a pipe and a block connector on it you cant really see the sensor as it sits under the bracket
Old Mar 15, 2007 | 09:37 PM
whittyscossy
cheers many thanx and thanx to cos400 for pic.
Old Mar 15, 2007 | 09:47 PM
SafeChav's Avatar
SafeChav
Its worth while putting cable ties on the pipe connections aswell
Old Mar 15, 2007 | 10:20 PM
whittyscossy
ok cheers m8 will do in the morning
Old Mar 16, 2007 | 12:49 AM
Billabong's Avatar
Billabong
The MAP sensor pipe is NOT the best place to be T'ing into!
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
IainRS1700T
Sep 25, 2015 06:44 AM
