BMW 318I
Old Mar 10, 2007 | 11:43 AM
Moonstone Kev's Avatar
Moonstone Kev
Default BMW 318I
ive got an 318i bmw, 2 probs with it when it,s idling it goes up to 1500 revs then back again the second prob is when you take the header tank cap off the water coming spitting out, ive been told there's to much pressure in the system, any help would be great
Old Mar 10, 2007 | 02:20 PM
For idling I would clean the idle speed control valve first.
As to pressure, if it does it only when HOT then that is ok so long as shows no signs of h/gasket failure, it is under pressure to raise the boiling point, if you remove the cap quickly it will spit water.
At the end of the day if it is not using water and not overheating stop worrying.
Oranoco
41
Feb 11, 2016 01:28 PM
Oranoco
12
Oct 2, 2015 02:18 PM
stevecfrst1
Sep 30, 2015 05:18 AM
`spotty
Sep 25, 2015 11:41 PM
Kam B
Sep 24, 2015 10:40 AM
