brake bias valve question
Old Mar 10, 2007 | 01:04 PM
16vzetec's Avatar
16vzetec
Default brake bias valve question
on a my car i have a 4 pipe master.
it is running diagnal at the moment.
how do i plumb in a bias valve?
someone told me to use front part for fronts and rearfor rears, my question is that is it ok to do that and what about the build up of pressure from the rears where the bias valve is only letting small amount pass, is that right??
Old Mar 10, 2007 | 04:14 PM
Aaroncast's Avatar
Aaroncast
bias valve-screw in to reduce fuild to front (or back) and visa versa-depending how you plumb it in-put all bias on the back to lock up rear wheels eliminating handbrake-SO YOU CAN USE BOTH HANDS TO STEER GREAT ON STAGES OR AUTO TEST-ETC.
(((((NOTE DANGER!!! )))))ON ROAD CAR YOU CAN LOOSE CONTROL AND CAUSE A BIG OFF IF YOU DONT KNOW WHAT YOUR DOING
yatta
May 21, 2016 10:31 PM
15
Oct 7, 2015 03:43 PM
xrmalin
Sep 13, 2015 06:52 PM
cossirob
Sep 3, 2015 09:17 PM
