fuel gauge question...
Old Mar 7, 2007 | 10:47 PM
rowen20's Avatar
rowen20
Default fuel gauge question...
right got my erst on the road and legal today... but when the car reaches quarter of a tank it runs dry of fuel.... heard of a few doing this before, is it just a case of a buggered sender unit? anyone got any ideas/had same prob before would be much appreciated
Old Mar 8, 2007 | 02:53 PM
SafeChav's Avatar
SafeChav
Could be a knakcered sender.
I know when i first got my cabby on the road though the gauge didnt work and i ran out of petrol every day for 10 days, so i fixed the sender as it was stuck, but then it would cut out well before the petrol light came on in the instruments, the one way valve was also knackered in the pump, and the pump was whining its tits off too!
Since changing my pump and one way valve its not been an issue since it runs forever and a day with the light on!
Old Mar 8, 2007 | 05:54 PM
ram's Avatar
ram
Has a large member
my old erst would run out of fuel when it was reading an 8th of a tank left. i was gonna get the sender changed but never got round to it.
never really bothered me though as id just make sure i never ran it down that far (although id still always fail that and end up stranded in places )
Old Mar 8, 2007 | 08:23 PM
SafeChav's Avatar
SafeChav
The instruments in a Mk4 do leave an awful lot to be desired.....shame they cut so many corners in the transition over from the Mk3
Old Mar 13, 2007 | 10:30 AM
rocky3410's Avatar
rocky3410
thats exactly like my fiesta... i would drive the car on a half tank for like half n hour....then park up go in my house come back out and on the gauge there would be no petrol! i dont know whats goin on with it lol but i think i fixed it! So gd luck with ur problem.
Old Mar 13, 2007 | 01:38 PM
You can always bend the float arm to give a different reading.
Old Mar 13, 2007 | 01:54 PM
SafeChav's Avatar
SafeChav
Sounds like the float on your sender may have a hole in it
i seriously wouldnt encourage people to do that! What a bodge!
Old Mar 13, 2007 | 04:10 PM
Oh really I wonder what they do when they are new ?
It is the arm/float that dictates the reading, and as it is sprung metal, unless you bend it for half an hour each way it is perfectly safe and what happens at the factory when they are made, maybe this is the reason they use stainless sprung steel ?
Old Mar 13, 2007 | 06:09 PM
SafeChav's Avatar
SafeChav
So your telling me when they build a car they put the sender in and if the gauge is out they BEND the arm.
What a load of bollucks!
How does a sender arm get bent inside a petrol tank aswell
Old Mar 13, 2007 | 06:25 PM
Try reading correctly, I stated that the arm is adjusted so that the float is causing the correct reading, some float arms have a natural bend in them to allow easier fitment in the tank.
I cannot see where I even suggested they do this on an individual basis for each and every car, mind you this is not what was asked for anyway which is probably why I did not say it.
You can exhibit your intellect in more useful ways than garbage you know.
Old Mar 13, 2007 | 06:35 PM
SafeChav's Avatar
SafeChav
I would read correctly if you spoke proper english! you do babble some rubbish!
What does "bend it half an hour each way" mean
And as you can see, from your quote above, you said they bend them at the factory!
Old Mar 13, 2007 | 11:48 PM
ram's Avatar
ram
Has a large member
Old Mar 14, 2007 | 01:45 PM
SafeChav's Avatar
SafeChav
Originally Posted by ram
You know the score
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
20/20 vision
Sep 29, 2015 11:27 AM
