Stuck sump plug
Old Mar 7, 2007 | 02:47 PM
bossoo8's Avatar
bossoo8
Default Stuck sump plug
I cannot get my sump plug off my car, has anyone got any ideas.
Old Mar 7, 2007 | 02:55 PM
vroomtshh's Avatar
vroomtshh
Leave it on the car......
And get a Pela oil removal tool
Old Mar 7, 2007 | 05:53 PM
*Bri.4.b.Cos*'s Avatar
*Bri.4.b.Cos*
Cunning idea, but a bit of a chew not to mention lazy
Have you tried vise grips, eagle beaks, 6 point socket?
Is it rounded off or just fookin tight?
you could take it to a local garage and get them to heat it up slightly
Bri.
Old Mar 7, 2007 | 07:51 PM
Get a new sump plug ready, then weld a old socket etc on the old one so that you can use the square of the ratchet on it, the heat of the weld will help break it free, also useful for rear diff plugs.
If it is not too far gone use a SIX point socket to remove old one.
Old Mar 8, 2007 | 04:36 PM
C0S_TURBO's Avatar
C0S_TURBO
I have used a hammer and a sharp chisel on the edge of the nut before. Have to be very careful. Once the seal was broken I used a large flat headed screw driver to undo the sump plug the rest of the way.
Hope this helps!
Old Mar 8, 2007 | 05:50 PM
ram's Avatar
ram
Has a large member
is it too tight? or rounded off?
Brickhouse
14
Oct 3, 2015 07:28 PM
Iain Mac
Sep 30, 2015 09:39 PM
muz
Sep 30, 2015 08:29 AM
deathrider666
Sep 28, 2015 06:12 PM
youngben
Sep 27, 2015 09:37 PM
