S2 having problems getting started
Old Mar 2, 2007 | 09:40 AM
gregors's Avatar
gregors
Default S2 having problems getting started
Hi there
The car was running fine, so i decided to but my new radiator and intercooler on there which i did.
It then fired up first time as it always does, and it ran for about 10 mins to bleed the system.
I then when to go and take it for a blast however it stalled, and i thought this may be because it had run out of fuel, so i left it for the rest of the day and i put some fuel in it this morning and its still not firing
Whats the things i need to check? The battery is fine, its cranking as it should do, i can hear the fuel pump priming, its then turning but not firing. If i take the oil cap off i can smell petrol in there so i suspect its getting fuel i just dont know why she aint firing
So any help on things that would be good to check would be of great help.
Old Mar 2, 2007 | 10:14 AM
antony215's Avatar
antony215
Escort Rs Turbo
Have you checked to see if your getting a spark???
Old Mar 2, 2007 | 10:31 AM
gregors's Avatar
gregors
my king lead is getting a spark so im presuming until i have someone along to help me that all my other ones are sparking.
I didnt even touch the leads so i know they are in the right order because it started yesterday.
grr thing is starting to piss me right off now.
Old Mar 2, 2007 | 10:36 AM
antony215's Avatar
antony215
Escort Rs Turbo
I'd take a plug out and see if your getting a spark to that getting a spark from the king lead just means your coil is working.
Old Mar 2, 2007 | 10:41 AM
gregors's Avatar
gregors
if i am getting a spark and fuel what else could it be?
Old Mar 2, 2007 | 10:47 AM
antony215's Avatar
antony215
Escort Rs Turbo
Are you getting fuel up to the injectors??
Old Mar 2, 2007 | 10:55 AM
gregors's Avatar
gregors
if i undo the bolts on the metering head slightly fuel leaks out so again im assuming fuel is going to the head
Old Mar 2, 2007 | 11:00 AM
antony215's Avatar
antony215
Escort Rs Turbo
Then id check to makesure your getting a spark to the plugs mate your dizzy might be fucked and your not getting a spark to the plugs.
Old Mar 2, 2007 | 11:17 AM
gregors's Avatar
gregors
i will check them however the dizzy is like only 4 weeks old
Old Mar 2, 2007 | 11:20 AM
gregors's Avatar
gregors
the radiator is brand new, but the intercooler is 2nd hand, that wouldnt be fooked and stop it from starting would it?
Old Mar 2, 2007 | 11:44 AM
gregors's Avatar
gregors
right definatly getting a spark, and definatly getting fuel but its just turning and turning but not firing.
What else could it be, its really starting to piss me off now i take one step forward and 5 back, its booked in to be setup next weeks so if it aint done buy then il be right fooked off
Old Mar 2, 2007 | 01:04 PM
antony215's Avatar
antony215
Escort Rs Turbo
Cant see that being the problem as it would take a fair bit to block it right up. You could try checking for air leaks
Old Mar 2, 2007 | 01:07 PM
gregors's Avatar
gregors
hmm its really starting to bug me, cant see any air leaks, there was one but it ran before with that leak and iv sealed it now anyway
Old Mar 2, 2007 | 01:11 PM
antony215's Avatar
antony215
Escort Rs Turbo
Id check all the hoses mate and makesure there tight if there is an air leak somewhere it will stop it from starting it's like when you take the oil cap off when the car is running it cuts out because that makes an air leak it the system
Old Mar 2, 2007 | 02:16 PM
gregors's Avatar
gregors
iv had a closer look just now and they all seem to be on pretty tight, this is really pushing me to my limits im now in 2 minds of wether to sell it even after spending all this money and time on it, im just getting really annoyed
Old Mar 3, 2007 | 03:43 PM
gregors's Avatar
gregors
right found out what the problem is, the hard breather pipe going to to the top of the plenum. If i take it off, it starts then revvs at like 4k, put the pipe on then it will idle like shit and loads of white smoke pours out the back....any ideas?
Old Mar 3, 2007 | 05:07 PM
antony215's Avatar
antony215
Escort Rs Turbo
Are you on about the pipe that goes from the brake servo to the plenum??
Old Mar 3, 2007 | 11:18 PM
LeviA's Avatar
LeviA
Ten mins isn't long to bleed the system. I'd of left if for at least 20 more then likely 30 mins. Worth another shot bleeding it bud!
Old Mar 4, 2007 | 06:46 AM
gregors's Avatar
gregors
i believe that may be the one, any ideas?
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
muffster
13
Sep 3, 2015 09:40 PM
nick8saff
Aug 16, 2015 05:35 PM
Sjieter
Aug 5, 2015 09:47 PM
