cosworth piston rings/con rods
Old Feb 28, 2007 | 06:47 PM
cossie0_4's Avatar
cossie0_4
Default cosworth piston rings/con rods
i am in the process of putting my block back together and i was wondering how i can tell on rings 1 and 2 there is usually a mark that says top but mine arent there anymore i know which 1 is top and middle ring but not how to tell top will this make any difference as i cant see any difference either way up also on the conrod on 1 side there is numbers and the other side is blank do these all need to face a certain way ie to front of block or does this not make any difference either any help much appreciated thanks
Old Feb 28, 2007 | 07:18 PM
cossie0_4's Avatar
cossie0_4
forgot to mention it a 2wd saphire cosworth
Old Feb 28, 2007 | 10:54 PM
cossie0_4's Avatar
cossie0_4
and mahle rings
Old Mar 1, 2007 | 06:05 PM
cossie0_4's Avatar
cossie0_4
have found out about piston rings just unsure of conrods any help cheers
James Porter
Oct 28, 2015 12:17 PM
KW-rscos
11
Aug 31, 2015 01:51 PM
Escortdriver1
Aug 31, 2015 11:19 AM
ekjim
Aug 17, 2015 08:57 PM
Aug 14, 2015 07:29 AM
