University Gearbox project.
Old Feb 28, 2007 | 09:21 AM
scotty86d's Avatar
scotty86d
Default University Gearbox project.
Ive got a project where I have to reduce the weight of a gearbox,
http://www.ondrives.com/products.asp?recnumber=33
I need to reduce the weight by 1/3 without compromising strength.
I was thinking of changing the material for the actual cogs from high carbon steel to nylon or possibly I was also thinking of the material used in the essex v6 that everyone replaces to steel or ally timing gear.
Does anyone know what that std material is or can lend any help?
thanks
scott
Old Feb 28, 2007 | 11:12 AM
jon@work's Avatar
jon@work
IIRC from the dim and distant past, the Essex timing gear is a metal gear with nylon teeth - this is replaced for a one-piece steel item, 'cause the nylon teeth fail
Old Mar 1, 2007 | 08:29 PM
*Bri.4.b.Cos*'s Avatar
*Bri.4.b.Cos*
Default Re: University Gearbox project.
Will this not affect strength
Bri.
gambo08
Feb 4, 2016 10:49 PM
mjonathan24
Oct 29, 2015 10:39 PM
Iain Mac
Sep 30, 2015 09:39 PM
SMILER258
Sep 28, 2015 09:04 AM
