mt75 help plz
Old Feb 22, 2007 | 11:55 PM
330bhpcoz's Avatar
330bhpcoz
Default mt75 help plz
i have a 4x4 sierra cosworth on a g reg,gearbox went,bought a nother mt75 the problem is the engine part fits ,but the back of the gearbox the little shaft wat goes in the prop it doesnt fit sonme help cheers
Old Feb 23, 2007 | 09:11 AM
2ndGear's Avatar
2ndGear
Default mt75 help
yeah the Late sapphires and escort cosworths had a different output shaft in the gearbox see pictures:
the best advise is to get the propshaft end to go with the box your fitting then its just a easy job other wise you have to take the transer off and swap the output shaft.
Old Feb 23, 2007 | 06:03 PM
330bhpcoz's Avatar
330bhpcoz
cheers m8 but mine is a 4x4 mt75 from a sierra cosworth its a G reg, i been told mine is a very early for G reg ,but wat really is the problem is that know its all fitted ,but wen u press the clutch pedal rite down it makes a loud sqeaking sound metalicy but all gear go in ,know if i dont go all the way down it does not make the noise and the gears go in fine say the pedal is about just under 1 inch from the floor ,if you no wat i mean ,also would changing a same gearbox for a nother 1 do that cheers
Old Feb 23, 2007 | 07:38 PM
2ndGear's Avatar
2ndGear
it must have had a box change before in its time. Do you need the longer output shaft or the shorter? You have definatly got a box from a cosworth because the 2.0 DOHC boxes look the same but clutch pivot & things are different and you could get that noise from that.
Old Feb 23, 2007 | 09:24 PM
330bhpcoz's Avatar
330bhpcoz
THE CLUTCH CABLE SIDE IS ON THE PASSENGER SIDE ,SO THE BOX I PUT ON IS A COSWORTH OR THE OLD 1 IS ? CHEERS
Old Feb 25, 2007 | 01:46 PM
330bhpcoz's Avatar
330bhpcoz
Old Feb 26, 2007 | 05:51 PM
330bhpcoz's Avatar
330bhpcoz
im still crying dunno wat to do start finish it doing my nut in
Old Feb 26, 2007 | 06:16 PM
eliters1's Avatar
eliters1
just had this,its the release arm for the bearing they split and crack then touch the flywheel you have to take it out and change it,transit suffered lots with it,so ford reinforced it with add on plate spotted all round.
Old Feb 27, 2007 | 09:39 PM
330bhpcoz's Avatar
330bhpcoz
Default mt75 noise etc/shaft
cheers m8 for the info ,tell me did your car do the same ,mine was that wen u put foot on clutch all the way down it screams and squeekes ,but if u press the pedal say leaving 1 inch or from the floor it does not make any noise,also my starter has stoppped it just spins
Old Feb 27, 2007 | 09:40 PM
330bhpcoz's Avatar
330bhpcoz
also is your car a cozzie 4x4
Old Feb 28, 2007 | 07:40 AM
eliters1's Avatar
eliters1
yes mines a h 4x4,unsure about the starter,but what happens is that the release arm breaks and when you press the pedal to the floor it moves forward more than it should and touches the flywheel which is spinning causing the noise,but if you release slightly it doesnt touch,hopr this helps will try find a pic of what i mean in a bit for ya and post it up.
Old Feb 28, 2007 | 08:33 AM
330bhpcoz's Avatar
330bhpcoz
cheers buddy ,so wats the solution for this ,does this mean the guy who fitted it should of checked it etc,also the guy did tell me that he changed the fork over from my old 1 to th e new 1 cheers help wouyld be most gratefull
Old Feb 28, 2007 | 01:13 PM
eliters1's Avatar
eliters1
he changed the fork over?
ask to see the old one maybe he took them both out and got them mixed up,when mine went it had a hairline fracture i couldnt see so changed the clutch then had the prob you have when took it back out could see the crack and had gone well out of line and was touching the flywheel causing the noise,would take it back if someone did it for you get them to sort it out.
Old Feb 28, 2007 | 02:46 PM
330bhpcoz's Avatar
330bhpcoz
cheers m8 will do
Old Feb 28, 2007 | 02:47 PM
330bhpcoz's Avatar
330bhpcoz
sorrry forgor,wat u reckon on the starter?
Old Feb 28, 2007 | 04:16 PM
eliters1's Avatar
eliters1
possibly the solenoid has packed in?remove it and leave dangling on wires,then use a jump lead fro its casing to earth it have soeone watch and try it,see if the solenoid chucks the wheel out and spins the otor as if solenoid has died will spin motor but not engage?
Old Mar 3, 2007 | 10:52 AM
330bhpcoz's Avatar
330bhpcoz
could i not just leave it all conected and take it out, and turn it with the ignition cheers
Old Mar 3, 2007 | 01:35 PM
eliters1's Avatar
eliters1
yes but you have to put a jump lead from the casing to earth as it normally earths thru the gearbox housing when its bolted in,
Old Mar 3, 2007 | 02:14 PM
330bhpcoz's Avatar
330bhpcoz
can i just wire all it up ,and then from the battery use the earth and toch the bolt were the solonoid is attached
Old Mar 4, 2007 | 03:22 PM
eliters1's Avatar
eliters1
easier if you remove starter clip[ one end to box housing and other to where bolt goes thru when its bolted to the box then try it mate
Old Mar 4, 2007 | 06:00 PM
330bhpcoz's Avatar
330bhpcoz
Default starter sorted /noise still there
all sorted changed starter,but still have the squeeling noise wen pedal push rite down help would be good cheers guys
Old Mar 4, 2007 | 08:41 PM
eliters1's Avatar
eliters1
so it was the solenoid in the end mate?
did you do what i said about the clutch release arm?
i can 99% guarantee will be this.
Old Mar 5, 2007 | 09:28 AM
330bhpcoz's Avatar
330bhpcoz
Default clutch noise
yes it was the whole thing ,but the noise is still there but ive put a stopper at the bottom of the pedal so it does not touch the floor ,but the gears are a bit stiff wat u reckon ?
Old Mar 5, 2007 | 07:57 PM
eliters1's Avatar
eliters1
would def still say it would be related to the clutch arm,as if it was not there before and now is which what hapened to me as well,if you take the box out should have scoring on front face of clutch pressure plate from whee it touches btw will eventually kill gearbox as the stiffness is caused because clutch is not disengaging properly and could stop diengaging at any tie if release arm snaps then ould have to be flat bedded home/garage for repair.
Old Mar 5, 2007 | 10:36 PM
330bhpcoz's Avatar
330bhpcoz
cheers m8 will try get it sorted so wat do i change it with the old fork that came with it as it was changed during exchange
Old Mar 5, 2007 | 11:45 PM
eliters1's Avatar
eliters1
i would check and compare them as could be slight difference,also look for hairline cracks or it maybe out of alighnment ie twisted post up pics mate if you can.
Old Mar 6, 2007 | 08:23 AM
330bhpcoz's Avatar
330bhpcoz
i will try cheers
Old Mar 10, 2007 | 08:30 AM
330bhpcoz's Avatar
330bhpcoz
Default mt75 help
cheers m8 for your help in the advert ,the thing is the mt75 which i took off my car had the long shaft ,the 1 i bought i had to get the matching prop why is that cheers plz help
Old Mar 12, 2007 | 08:10 PM
330bhpcoz's Avatar
330bhpcoz
all sorted ,the clutch cable needed a spacer , the fork was traveling to far touching ......
mjonathan24
Oct 29, 2015 10:39 PM
Iain Mac
Sep 30, 2015 09:39 PM
cossie brad
Sep 29, 2015 02:38 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
Old ford
Jul 31, 2015 06:50 AM
