adsusted cambelt on rst now wont start
#44
forgot to mention that the odd time it did run yesterday i had the timing light on and according to the light it was nearly 90 degrees out?
#46
Escort Rs Turbo
#47
how can i change it though,it wont run properly to let me set it up with the timing light,and it still runs like shit when i twist the dizzy either way
#48
If your timing is 90 degrees out then that can only be having the dizzy leads 1 place out
Was that when you got it running with the dizzy in the middle of adjustment?
#50
#52
The above picture is with the timing marks set to 12 o'clock (assume thats TDC)
Thinking about it now, is there 2 ways that the distributor could fit into the end of the cam shaft? As it only fits into the slot. I never took much notice when i put it together.
JK12
33
26-04-2021 12:09 PM
