ANOTHER 3 DOOR PROBLEM
Old Jan 13, 2007 | 07:01 PM
Harris.'s Avatar
Harris.
Default ANOTHER 3 DOOR PROBLEM
Went to get the car out the garage today for the 1st time in a few weeks, and the car wont rev no more than 2800 rpm (when the turbo comes in) soon as it his 2800rpm the red light on the dash comes on and the car goes to stall .............................then the idle valve keeps it alive.
Does anyone know what is causing this
dave
Old Jan 13, 2007 | 07:10 PM
witch red light
Old Jan 13, 2007 | 07:11 PM
Harris.'s Avatar
Harris.
Theres a light on the dash with a picture of a engine ? warnning light!!! It wont rev above 2800rpm
Old Jan 13, 2007 | 07:12 PM
Alvyn's Avatar
Alvyn
sounds like it's a boost problem and engine management is closing it down(safe mode) start by checking ALL connection,amal valve and ecu plug at a guess!
Old Jan 13, 2007 | 07:16 PM
Harris.'s Avatar
Harris.
Originally Posted by Alvyn
sounds like it's a boost problem and engine management is closing it down(safe mode) start by checking ALL connection amal valve and ecu plug at a guess!
Erm whats the amal valve mate and where is it located
Old Jan 13, 2007 | 07:19 PM
Alvyn's Avatar
Alvyn
Erm whats the amal valve mate and where is it located [/quote]
If it's still there and your car is standard spec it will be on top of the i/cooler!
Old Jan 13, 2007 | 07:20 PM
Alvyn's Avatar
Alvyn
Originally Posted by rob v
which red light
3drs have an engine management light in the dashboard!
Old Jan 13, 2007 | 07:22 PM
which red light
Old Jan 13, 2007 | 07:25 PM
Alvyn's Avatar
Alvyn
which red light
no need for that m8 as EVERYONE can learn something new every day
Old Jan 13, 2007 | 07:39 PM
which red light
Old Jan 13, 2007 | 08:14 PM
Harris.'s Avatar
Harris.
Yeah its only stage 1, so it still has that valve , if i disconect it i can hear a clicking, why the car is running that is .................... How do i test this
What else ??????
Old Jan 14, 2007 | 09:36 AM
Harris.'s Avatar
Harris.
Hi mate,ive looked at these today and everything seems normal. The car starts fine and runs untill you hit boost then the rev counter drops too 0 but the engine is still running,hit the accelerator and the rev counter jumps to idle again , even tho the red light is still on ???????? Basicly i can drive the car but cant go above 2800 rpm or it jults and the revs drop
HELP
Old Jan 14, 2007 | 01:10 PM
Alvyn's Avatar
Alvyn
IS the above from cold or from once cars warmed up?
take the dissy cap of and have a look at the phase sensor condition of the wires and the size of the gap!
Old Jan 14, 2007 | 01:43 PM
Harris.'s Avatar
Harris.
Dont matter if its hot or cold its still the same ive put another map sensor on it and it didnt change anything , just got to look at the phase sensor now
Old Jan 14, 2007 | 07:02 PM
Harris.'s Avatar
Harris.
All is ok, i really duno where to look next
Old Jan 14, 2007 | 07:30 PM
Alvyn's Avatar
Alvyn
check the tps sensor and also a try another ecu L1 or a L6 one out of a saff (with a standard or stage 1 chip) WILL do just to try out straight plug in with NO other changes needed!
Old Jan 14, 2007 | 08:39 PM
Harris.'s Avatar
Harris.
Just been out there again,from cold it was ok, soon as it warmed up reved it up loud pop from the exhaust and ON came the red light ,it has got a L6 ecu from a saff I will see if i can get hold of another ecu this week, if that fails im going to burn it
Thanks for your help alvyn
Old Jan 15, 2007 | 07:10 AM
Have u tried the water temp sensor on the passenger side at the back of the head.It sud b a blue connector a bit of a pain 2 find u have 2 take the hose off to get at it.
Old Jan 15, 2007 | 12:50 PM
Harris.'s Avatar
Harris.
Yeah ive changed that too !!! would this cause the red light to come on?? been told ...........throttle position sensor ?????????????? How do i test/remove this?
Old Jan 15, 2007 | 04:18 PM
Alvyn's Avatar
Alvyn
change the coolant sensor 1st m8!
Old Jan 15, 2007 | 04:48 PM
Harris.'s Avatar
Harris.
Done that alvyn ,ive sent you a pm !!
Old Jan 16, 2007 | 07:37 PM
mapcossie's Avatar
mapcossie
had the same problem, changed every sensor but didnt fix it ! it was the ecu , tryed 3 level 1 ecu's but couldnt find a good 1 ! so used a level 6 , it cured it straight away .
Old Jan 16, 2007 | 08:56 PM
Harris.'s Avatar
Harris.
Mines going to be sorted tomorrow, as i aint got a clue what else it could be ,should have it back by the weekend
Thanks for all the help !!!
3drRich
Sep 13, 2015 07:32 PM
leep27
Ford Mondeo Including ST
Aug 22, 2015 01:52 PM
no1trancefan
Ford Focus ST
Aug 6, 2015 05:09 PM
