BROWN OILLY SLUDGE IN TURBO AND CHARGE PIPES
Right i thought the oil return was blocked makin oil go into the turbo pipes on my s2 erst so cleaned it out after replacing all the pipes and takin it 4 a little spin i checked the pipes again now there full of light brown oil im hoping the head gasket aint gone im thinking that the oil seals have gone in the turbo but does any1 know if they go that trhere must be seals 4 the water with it being water cooled that they might have gone asd well
any help would be great cheers in
Escort Rs Turbo
If i was you id be hoping the seals aint gone in the turbo rather than the worrying about the headgasket headgasket is about £30 a turbo rebuild is £350+ do a compression test on the headgasket takes about ten min's mate then you'll know if the gasket is fucked or not
HI AGAIN M8, YE BUT THERES WATER WITH IT AS WELL I WAS THINKING THE OIL SEALS IN THE TURBO HAve defo gone so do you think the seals for the water chambers to cool the turbo could have gone to make the water mix with the oil
The only way oil can mix with coolant from the turbo is if its crakced.
Not being funny mate but i did tell you long ago to have a compression test done, your taking guesses and thats usually a fairly good way of wasting money on things that you don't need.
Ye i know what u saying m8 but only money ive spent so far is for that turbo but solt it and got my money back, be rights i think im just guessing tho tryin to think its things that its not i think im just going to let a mechanic have a look befoere i do spend anything on it
Escort Rs Turbo
You maybe lucky and the headgasket and the oil seals may be fucked then if you've got ALOT of what looks like
in your pipes
Do a compression test(or take it to a garage and they will do it for you) mate then you will know for sure weather your headgasket is gone or weather the water way in the turbo is cracked ect.. it's a process of elimination mate but you ALWAYS!! start with the cheapest things first because like safechav said guess work can just become an expensive hobby
in your pipes
How many miles on the car/engine?? any photos of engine bay??! forget the turbo for awhile -start with a cylinder pessure test- remove plug insert tester and turn over( remove center ht lead so it just turns over and wont fire up/run). make a note of the reading, then do each one in turn, its no good sorting a tuRbo problem out if its the head gasket etc----------DO AS YOUR TOLD KHANNY-LOL- KEEP HAPPY IT'LL GET SORTED-speak soon.
Cheers 4 the repliys guys im trying to get hold of a tester any1 know were to get 1 from ive tryed all the car shops round here wiv no luck what is the actuall name for the tester any ideas how much and how much to get it done at a garage.
Escort Rs Turbo
There £23.50 + P+P from www.burtonpower.com this is what they look like
https://www.burtonpower.com/pic_view...ge/ITC9090.jpg
i cant see the garage being cheaper than buying you own one mate
andy130
02-10-2015 08:48 PM
Matt Baxter
16-09-2015 08:30 PM
