3 bar MAP sensor versus 2.5 Bar
Old Dec 5, 2006 | 09:21 AM
Carter's Avatar
Carter
Default 3 bar MAP sensor versus 2.5 Bar
Im trying to trouble shoot the limp home mode on my escort cosworth and would like to try another MAP sensor. I have a spare 3 bar one, can anyone tell me if i can run this on a standard escort in place of the 2.5 bar unit, and will the car run normally or will the ecu not allow it.
Many thanks.
Old Dec 5, 2006 | 11:06 AM
AX Cossie's Avatar
AX Cossie
It may run but not properly.
The map sensor is just a device which sends the ecu an electrical signal.
e.g. if the scale was 0-1v
So if you 2.5MAP, 2.5bar will 1v
If u use a 3MAP , 3 bar could be at 1v
Therefore u run the risk of detonation cos your running lean.
Old Dec 5, 2006 | 12:40 PM
foreigneRS's Avatar
foreigneRS
Testing the future
it will idle and drive on part throttle ok ish, but i wouldn't want to drive it on boost
Old Dec 5, 2006 | 07:40 PM
Carter's Avatar
Carter
Thanks guys, dont think ill risk it, have to find a 2.5 to borrow (like rocking horse S@#T here in NZ) PS to those that posted the info about replacing the inverter for the dash light problem, excellent info, sorted that problem.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
jay030787
Sep 25, 2015 01:38 AM
