Gearbox oil
Old Dec 29, 2003 | 09:20 PM
Default Gearbox oil
What type or what grade of gearbox oil is used in a gearbox of a (sapphire) cosworth, 75w90 or 80w90
Greetz
Old Dec 29, 2003 | 09:59 PM
Stu @ M Developments's Avatar
PassionFords Creator
What Sapphire mate? 2wd or 4wd?
Whichever it is, its neither of those oils, so dont rush off
Old Dec 29, 2003 | 10:26 PM
GaryEvo's Avatar
GaryEvo
off the top of my head i thought it was 75w90 syn
Old Dec 29, 2003 | 11:02 PM
Fraid not mate.....
Old Dec 29, 2003 | 11:36 PM
extra17's Avatar
extra17
so what is it
Old Dec 30, 2003 | 07:21 AM
RSrussell's Avatar
RSrussell
Oil; Ford Specification SQM 2C 9010 A
2.6 Litres
Dunno what it means but there ya go
Old Dec 30, 2003 | 09:12 AM
GaryEvo's Avatar
GaryEvo
mtx75 4x4 gearbox takes 75w90
t5 takes auto transmission fluid (atf dexron 11)
but check with a manual
Old Dec 30, 2003 | 09:25 AM
Ok,
Lets clear this up then
The T5 manual takes Dexron II as Gary rightly says..
However:
The MT75 found in all 4wd cosworth variants absolutely MUST be used only with special MT75 Transmission fluid.
I personally use Castrol FMT.
Old Dec 30, 2003 | 09:30 AM
GaryEvo's Avatar
GaryEvo
sorry stu id just looked on here.......doh
http://www.grahamgoode.com/rnr2.htm
Old Dec 30, 2003 | 09:44 AM
No probs Gary
I recon we should ask Bernie to clear this up actually, as ive also heard that using non MT oils is ok, but i personally believe it to be a bearing material issue.
Be interesting to know once and for all from a transmission professional
Old Dec 30, 2003 | 10:02 AM
gearboxman's Avatar
gearboxman
O.K.
Cosworth T5: Dexron II
Cosworth MT75: MT75 fluid
RS2000 MTX75 up to 1995: MT75 fluid
RS2000 MTX75 1996 model up: SS75W/90
Note: I recommend the use of a full synthetic 75W/90 on "big tooth" motorsport gearsets, but on all of these boxes you will need to get the box warm before expecting a quick gearchange
Old Dec 30, 2003 | 10:07 AM
gearboxman's Avatar
gearboxman
Sorry, forgot to mention transfer boxes
Cosworth MT75 transfer: DexronII
RS2000 MTX75 transfer: MT75
Old Dec 30, 2003 | 10:16 AM
Whilst were here then Bernie.......
Whats the difference with Dexron II and III?
Ive presumed III is a better spec but simply never used it as i dont "know for a fact"
I called Castrol Tech once with this issue and they didnt know either
Old Dec 30, 2003 | 10:28 AM
gearboxman's Avatar
gearboxman
The later Dexron III is supposedly friendlier on the solenoids of the modern day "managed" auto transmissions.
I would expect it to have a slightly higher detergent level, along with improved anti-foam properties (which is generally what the Dexrons were about)
Old Dec 30, 2003 | 10:40 AM
So of no discernable benefit to a T5 unit then?
Thanks you Bernie. Much appreciated Info.
Old Dec 30, 2003 | 10:41 AM
gearboxman's Avatar
gearboxman
No
Old Dec 30, 2003 | 09:29 PM
The T5 gearbox is a 2wd gearbox???
Rare question, what color is Dexron II is it blank or red like aut.transmission fluid, because the color of the oil that's now in the gearbox is blank.
BTW thanks for the reply's
Greetz
Old Dec 30, 2003 | 09:35 PM
RSrussell's Avatar
RSrussell
Yep
the mt75 is the one fitted to the 4wd cosworths
Old Dec 30, 2003 | 11:09 PM
Its red 9 times out of 10 mate
Old Dec 31, 2003 | 05:42 PM
I Asked because the fluid that's now in the gearbox is blank but when you guys say there must be dexron II in the gearbox then I will do that
Greetz and thanks
Old Jan 1, 2004 | 02:25 AM
Pleased to help
TPM961
Jan 15, 2018 10:50 AM
IainRS1700T
Sep 25, 2015 06:44 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Flateric_2002
Sep 15, 2015 08:41 AM
Adam Graham
Sep 6, 2015 06:04 AM
