TPS and ISCV - what's the score
0-60 in 17 seconds (eek)
Ok, my 4x4 sapph cos hunts at idle when i rev her up to 3k and let go of throttle, more often than not she stalls.
This is when the engine has warmed up, when cold, all is fine.
I tried to disconnect the ISCV but the engine won't start and stalls if I disconnect it while it's running.
I disconnected the TPS, no more hunting, but idles at 1200 or so.
Can a diagnosis be made from that ?
Is the car safe to drive with TPS disconnected while I find a solution ?
Thanks and have a great week end.
Greg
Greg
sounds like u need to set the base idle..
the idle speed adjustment screw is on the bottom of the throttle body -
disconnect the idle valve and adjust the idle speed bypass screw so that the engine idles at specified speed - 850-900 rpm.
Reconnect the idle speed valve, the revs shouldn't alter.
Thanks whitneyd, the idle was just set too low, I raised it and now everything seems ok.
Thanks for the warning.
What you doing in Italy ???
DixieTheKid
11
06-06-2020 11:20 AM
