COSSIE OVER FUELING
Old Oct 23, 2006 | 09:48 AM
STUCOS's Avatar
STUCOS
Default COSSIE OVER FUELING
Hi folks wounder if any body can help,my bloody 3dr is over fueling realy bad,put new engine in which is completley built from new block,all sensors are new,runs dark greens with t38 on l1,got kenny at msd to write a base chip for it ,just till i get it live maped on l8 with siemens inj,starts off the key no problem but as soon as you try to give it ant throttle you can feel it flooding it self with fuel,give it hard throttle and it belches out black smoke and is very rough,hope somebody can help as im going demented,oh and yes fuel pressure is correct
cheeRS stu
Old Oct 23, 2006 | 11:08 PM
2001ode's Avatar
2001ode
Hi,
May be you have one injector always open by short circuit on wire.
It was an old campaign on RS .
Check your wire on injectors, or near, if wire is in short circuit and maintain one injector opened.
Regards.
Claude
Old Oct 24, 2006 | 05:28 AM
Alvyn's Avatar
Alvyn
I would check the tps settings,fuel regulator,map sensor and also coolant temp sensor or at least the 2 wires that go to it to make sure they are actually connected to the sensor!
Old Oct 29, 2006 | 08:53 AM
STUCOS's Avatar
STUCOS
Alvyn,all are new apart from tps sensor,car ran fine when i took old engine out last year,didn,t want to replace tps just know as car will get converted to l8,after kenny did me a base map the over fueling is better,did think about an injuctor leaking,thinking about fitting an secs monitor would this give me any usefull information
cheeRS stu
Old Oct 29, 2006 | 10:39 PM
Ben M's Avatar
Ben M
Default over fuel
hi try checking the gaps on ure new sensors i can tell u what the should be if u need to know
Old Nov 5, 2006 | 09:55 PM
STUCOS's Avatar
STUCOS
What should the gap on crank sensor be
cheeRS stu
Old Nov 5, 2006 | 10:49 PM
2001ode's Avatar
2001ode
Hi,
Crank : 0,4 mm. / 1,0 mm.
Phase : 0,2 mm. / 0,3 mm.
Regards
Claude
Old Nov 14, 2006 | 08:26 AM
YBJ's Avatar
YBJ
Thinking Cosworth..
This is very interesting.. cause if the gaps of these sensors can make it overfuelling I assume they can also make the mixture too lean??
What's the explanation for these sensors that they have influence on the mixture of the engine?
Is there someone who knows the technical know-how about this??
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
Cossiesteve
Ford Escort RS Cosworth
Sep 17, 2015 12:37 PM
kevin36
Sep 8, 2015 12:23 PM
Thanasis
Sep 7, 2015 07:33 PM
