Non Starting Erst S2 please help
Old Sep 14, 2006 | 06:52 AM
tezza_RS's Avatar
tezza_RS
Default Non Starting Erst S2 please help
Hi Guys n Gals
I'm having a few problems with my S2. it's been running fine and yesterday went to start it and it just turns over. there is spark and fuel, changed the dizzy cap and rotor arm yesterday, it's got about 3/4 fuel, new spark plugs and ht leads. it seems like it wants to start but there is something just holding it back. really frustrating as it was running so well.
Please help
Thanks in Advance
Matt
Old Sep 14, 2006 | 11:38 AM
tezza_RS's Avatar
tezza_RS
BTTT
FelthamRST's Avatar
FelthamRST
have you tried the compression mate?? might be summit like a head gasket?? depends on how new it is and how much hammering u give it?
Old Sep 14, 2006 | 11:40 AM
tezza_RS's Avatar
tezza_RS
I've only really just got it on the road it's had a new head gasket and i rarely drive it hard. comp was 150 over all 4 cylinders.
Old Sep 16, 2006 | 07:15 PM
coss1e2000's Avatar
coss1e2000
Does the engine turn over at normal speed or slowly? CVH's suffer from lazy starter motors
Old Sep 16, 2006 | 07:56 PM
SafeChav's Avatar
SafeChav
If you have no spark or fuel, i would bet you a jam tart the sensor in the distributor body has failed.
Does the pump prime when you switch the ignition on?
Old Sep 18, 2006 | 06:59 AM
tezza_RS's Avatar
tezza_RS
No mate the pump doesn't prime when switched to ignition but you can here it if you stop crankingit over. will this be the pump? the fuel pump relay is new. is the sensor on the dizzy the black on on top of it?
Old Sep 18, 2006 | 11:12 AM
SafeChav's Avatar
SafeChav
This is an unusual fault then. If the pump runs while you are cranking the dizzy is ok. The lack of priming is usually a faulty relay, which makes it even stranger.
Old Sep 18, 2006 | 11:39 AM
tezza_RS's Avatar
tezza_RS
It is strange, going to get a fuel pump ordered later today. might call the aa out to it got home start, just to see if they can get it going or even just find the fault?
Old Sep 18, 2006 | 01:58 PM
SafeChav's Avatar
SafeChav
DON'T buy a pump you are wasting your money at this stage i can tell you that much.......
You would do better to find the cause of losing the spark first, fuck the priming for now thats by no means critical.
Old Sep 19, 2006 | 08:00 AM
tezza_RS's Avatar
tezza_RS
So where do you think i should start looking? i know the leads and plugs dizzy cap and rotor arm are new. what next?
Old Sep 19, 2006 | 09:57 AM
SafeChav's Avatar
SafeChav
Check the sensor in the dizzy, check the coil, etc
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
TPM961
Jan 15, 2018 10:50 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
