koni question
Old Aug 28, 2006 | 12:12 PM
bigmatt-s2rst's Avatar
bigmatt-s2rst
Default koni question
i have a set of rear koni adjustables for my rs turbo, i fancy havin a go at converting em to coilovers like the mk1 and 2 escort boys do
i have access to a machine shop so making up the threaded sleeves, nuts, and tops wont be a problem
my question is can u remove the inserts from the konis easily and refit them or is it an impossible task, reason being i dont want to weld the sleeves on and them blow up with the excess heat
hope someone can help
Old Aug 29, 2006 | 01:58 PM
JesseT's Avatar
JesseT
Don't know if there are any inserts in RST Konis, but certainly not in the way as in mk1/mk2 Escorts where the strut and shock are two separate parts.
Old Aug 29, 2006 | 09:46 PM
bigmatt-s2rst
decided this is a cheap skate way of coi overs that maybe wont even work!!!
decided just to invest in a decent set of specific springs!! any idea what poundage is best for a stripped out s1??
Nov 1, 2015 06:53 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
