Cossie Fuel Regulator Set UP
Old Aug 19, 2004 | 04:20 PM
scooby8272's Avatar
scooby8272
Default Cossie Fuel Regulator Set UP
The one with three pipes.
Their is one pipe with two outer screw holes.
One pipe on the side
and one tiny pipe.
Which is which ?
Old Aug 19, 2004 | 05:58 PM
CosRush's Avatar
CosRush
Little connection on the top is the vacuum connection to the plenum.
Bigger one on bottom is the Main Fuel Inlet, which leaves the side exiting one to the Fuel Rail.
hth
Old Aug 19, 2004 | 08:00 PM
pugo's Avatar
pugo
Default f/press/reg
i thought the one on the bottom was the return to the tank???????
Pugo
Old Aug 19, 2004 | 09:01 PM
CosRush's Avatar
CosRush
Sorry
My mistake.
You're right. Bottom is return
Old Aug 19, 2004 | 09:03 PM
scooby8272's Avatar
scooby8272
Which is Which on this pic please....
Old Aug 19, 2004 | 09:15 PM
CosRush's Avatar
CosRush
Regulator is upside down in pic
In pic...Small bottom one is Vacuum (inlet plenum)
Side bigger one is to Fuel Rail
Top Big one is Fuel Return...
HTH
Old Aug 20, 2004 | 12:03 AM
richm's Avatar
richm
In pic...Small bottom one is Vacuum/boost (inlet plenum)
HTH
correct
Old Aug 20, 2004 | 08:28 AM
scooby8272's Avatar
scooby8272
Cheers for that.
I could not stand it up the other way round.....
FlashRS
Aug 30, 2015 08:07 PM
jc1989rs
Aug 30, 2015 06:32 AM
Steve Escos
Aug 24, 2015 07:56 AM
kosienutter
31
Aug 22, 2015 09:55 AM
RSMK4TURBO
Aug 13, 2015 08:06 AM
