3 door ....poor running ????????????
Old Dec 21, 2003 | 08:25 PM
gazcos's Avatar
gazcos
Default 3 door ....poor running ????????????
I tried to run my cossie up today, just to warm it through as its laid up at the moment but it is missing really badly. It starts ok but you have to use the throttle to keep it running and it smells very rich and fumey, any ideas ??????
Old Dec 21, 2003 | 08:27 PM
swerv's Avatar
swerv
sensor at back of head??
Old Dec 21, 2003 | 08:32 PM
Any moisture in the dizzy cap?
Old Dec 21, 2003 | 09:25 PM
XR4Timan's Avatar
XR4Timan
plugs if I had to guess - but check:
* if dump valve, remove vacumn hose and plug it while running and see if it improves
* spray carb cleaner around hose connections/intercooler to see if the engine revs up
* remove Idle Control valve, clean with towel and reinsert
* pull out spark plug and check how sooty it is - change if necessary
Old Dec 22, 2003 | 01:01 PM
Steve Rst's Avatar
Steve Rst
Sounds like its knackered!
Tell you what, I'll take it off your hands for free!???
Old Dec 22, 2003 | 02:38 PM
Gav Diamond's Avatar
Gav Diamond
Map Sensor gone down?
Or dirty/broken crank sensor?
Old Dec 22, 2003 | 02:47 PM
scottbrown's Avatar
scottbrown
maybe its just saying " i want to be driven more often not locked up in this smelly garage" lol
Old Dec 22, 2003 | 02:51 PM
Jim Galbally's Avatar
Jim Galbally
broken dumpvalve will only cause faults on small turbo not latge turbo (dunno wot one yours is)
misfire would cause rich smell if its a bad miss...
Old Dec 22, 2003 | 03:11 PM
big_wig_074's Avatar
big_wig_074
try plugs mate!
Old Dec 22, 2003 | 04:28 PM
I am having the same problem as well, I think it could well be the blue coolant sensor at the back of the head causing the engine to overfuel when cold and foul the plugs.
Old Dec 22, 2003 | 04:40 PM
SPADGE's Avatar
SPADGE
Its a 3 door Jim!
Old Dec 26, 2003 | 08:29 PM
gazcos's Avatar
gazcos
I,ve found it. It was a bared wire coming out of the MAP sensor plug rubbing on the earth strap It,s nearly ruined my Christmas and Nearly caused a divorce ( It kept popping out to garage to try different things and the mrs was getting a bit ) Thanks to all those who made suggestions ,Gaz
Old Dec 26, 2003 | 08:31 PM
POPEYE's Avatar
POPEYE
FAIRY CAKE
glad its sorted dude
Old Dec 26, 2003 | 10:44 PM
SteveB's Avatar
SteveB
At least it was a cheap fix.....
Old Dec 26, 2003 | 11:43 PM
XR4Timan's Avatar
XR4Timan
Like a handjob, it's was a cheap fix Bet thoughts of selling the car crossed ur mind!!
Old Dec 27, 2003 | 11:10 AM
gazcos's Avatar
gazcos
I dont know about selling it , setting fire to it crossed my mind though !
Old Dec 29, 2003 | 08:26 PM
SteveB's Avatar
SteveB
Swap ya
3i Jim
Nov 20, 2015 05:12 AM
Indyrs
20
Sep 1, 2015 09:04 AM
leep27
Ford Mondeo Including ST
Aug 22, 2015 01:52 PM
saph in dorset
Aug 14, 2015 10:10 AM
dal3door
Aug 13, 2015 06:55 AM
