endura di pump
hey guys going to fit an endura di engine at the weekend but i have a question b4 hand
on this model it has a fly by wire throttle system (no cable) witch is on the deisel pump
on the other engine it has the pump already fitted (same engine) can i use this 1 or do i have to use the old 1 thats calabrated to the original ecu
if so is there a key way in the pump to set up the timing
thanks guys
its a 1.8 endura di engine 2001
pump on both are bosch vp30
tommy[/code]
thanks guys
tommy[/code]
SMILER258
Sep 28, 2015 09:04 AM
