zetec turbo ? exhaust studs? how deep do i drill?
i want to drill the exhaust manifold studs in my zetec turbo head and am wondering how deep i can drill BEFORE i go into oilways? anyhelp appreciated, cheers
just drill as deep as the studs need.
You WILL inevitably break out into oil return channels, don't worry about it, there is no pressure, just return drains, make sure you clean everything out properly afterwards and use oil resistant sealant on the stud threads when you fit them.
the wall thickness isn't sufficient in some of the positions that the studs need to go to not drill "through" - maybe 8mm or so thick. Thick enough to form a decent thread, but certainly not to avoid breaking through.
http://www.rsrich.force9.co.uk/zetec-turbo/Engine.htm
you can see in this picture how thick the casting is in the new thread at the right hand side of the picture:
Originally Posted by Simonne RS
r sayin 8mm is my safe bet? cheers
