s2 wiring problem
Old Aug 3, 2006 | 07:54 AM
krisberic's Avatar
krisberic
Default s2 wiring problem
Bought a s2 the other day and noticed that for some reason some body has run a live fused feed from the battery straight into the car wich seems to power the wipers and the heater fan dosent work. Is there a common fault with the fuse box.
Old Aug 3, 2006 | 11:11 PM
neds2rst's Avatar
neds2rst
fuse box is prone to corrosiion mate mines does that give heater fan fuse holder a clean up and try giving fuse a wiggle about with fan and ignition on and see if it just bad connection in fuse box
Old Aug 4, 2006 | 09:04 AM
krisberic's Avatar
krisberic
Default rs wiring
Had a look under fuse box, Its like a bomb under there there are connections all over must have been a problem, i think ill leave it to an auto electrician.
The Enigma
Sep 12, 2015 10:12 PM
Si B
Sep 12, 2015 06:49 AM
ward1174
Sep 12, 2015 03:34 AM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
routemaster
Sep 7, 2015 05:27 PM
