Smoke, But why??? *****SORTED*****
Old Jul 23, 2006 | 08:44 PM
Avinitlarge's Avatar
Avinitlarge
Default Smoke, But why??? *****SORTED*****
My car smokes on idle, Its like a blue/grey colour, Doesnt do it all of the time either, 99% onf the time it does it if the car has been stood over night or all day at work, It sometimes does it when the engine is warm. There is no oil blowing from the DV, The engine isnt breathing.
Could it be caused be excesive over fueling causing bore wash????
Old Jul 23, 2006 | 11:53 PM
antony215's Avatar
antony215
Escort Rs Turbo
Could be valve stem seal's
Old Jul 24, 2006 | 12:10 AM
Avinitlarge
Had new ones fitted 2000 miles ago along with a full rebuild
The smoke smells very petroly
Old Jul 24, 2006 | 12:17 AM
antony215's Avatar
antony215
Escort Rs Turbo
Over fueling is usally black smoke
Old Jul 24, 2006 | 09:16 AM
Avinitlarge
I know but it just smells very rich.
Maybe another clue here, Just started it, Took 5 and a half mins before any smoke appeared
Old Jul 25, 2006 | 11:29 AM
LEE-RS's Avatar
LEE-RS
Custom
could be over fueling alot and causing bore wash where it washs all the oil from the bores then gets pumped back up into the combustion chamber
Avinitlarge
Its got worse now, Quite alot of smoke on idle most of the time now, I am thinking bad things
Old Jul 26, 2006 | 08:23 PM
Avinitlarge
Here is another clue, Once its warmed up and I hold it at 1500 rpm it smokes alot
Old Jul 27, 2006 | 12:10 AM
antony215's Avatar
antony215
Escort Rs Turbo
Dose it use alot of petrol?? could be the seal's gone in the turbo
Old Jul 27, 2006 | 12:49 PM
Avinitlarge
About 20 MPG
Old Jul 28, 2006 | 09:00 PM
Avinitlarge
Ok,
Ive checked all the breathers, All clear
I checked for play in the turbo, There is a tiny bit but no more than when I fitted it
I turned the mixture down as far as it would go, The idle has become very lumpy
Still smells a bit rich
Held the revs at 1500rpm, Still smokes but very little
Drove down the road and came to a junction, Slowed down and there was quite a bit of smoke.
Went for a good thrash for 10 mins then pulled up at a petrol station and left it to idle whilst I checked my tyre pressures, No smoke
Drove back home, Stoppped at a junction to turn right, When I set off there was a puff of smoke, Pulled down the drive and left it to idle for a min or so, No smoke
So is it down to bore wash, Duff turbo or summat else
Old Jul 29, 2006 | 07:05 PM
Avinitlarge
I guess no one know, Its thrashing my head now
Old Jul 29, 2006 | 07:36 PM
antony215's Avatar
antony215
Escort Rs Turbo
Whe you say play in the turbo is it side to side or in and out?
Old Jul 29, 2006 | 09:51 PM
Avinitlarge
in and out, It had the same amount of play when it was fitted, There is only a VERY tiny amount, I know in and out play isnt good but I had about 3mm in and out play on my last turbo before it smoked alot
Old Jul 29, 2006 | 09:58 PM
antony215's Avatar
antony215
Escort Rs Turbo
Like you say in and out play aint good so i would think it was the turbo fucked whats it like on boost dose it smoke alot??
Old Jul 29, 2006 | 11:10 PM
Avinitlarge
No, No smoke on boost, No oil in the IC pipes
Old Jul 29, 2006 | 11:48 PM
pee vee's Avatar
pee vee
is it pissing thru oil?
Old Jul 30, 2006 | 10:51 AM
Avinitlarge
I did an oil change about 300 miles ago, It has lost a very small amount, About 3mm under max
Old Jul 30, 2006 | 12:37 PM
Avinitlarge
Sorry, I was wrong, Just checked again, It has lost about half a mm of oil and it was 420 miles ago when I changed the oil
Old Jul 30, 2006 | 04:42 PM
SWITCHBLADE's Avatar
SWITCHBLADE
Passionate about fords
ello mate, ive got a similar prob......my rs especially if its not driven for a little while smokes sometimes........theres no smoke at all on start up it usually happens after around ten mins of driving.......my smoke is thick white smoke........comes pooring out like im driving a steam engine...........if it doesnt clear straight away then i park up and turn the ignition off.......after bout 15 mins ill start her again and nothing what so ever happens, drive round for the rest of the night and shes perfect.
ive checked for play in my turbo......absolutely perfect no play at all, checked all the boost pipes and theyre clear also. i checked the turbo itself in case its leaking oil between the compressor housing etc and perfect. i had a compression test carried out and theyre also perfectly fine.
ive recently changed my valve stem seals, valve springs, retainers, and followers ( they were failing slighty ). that was two days ago now and apart from when i had just finished changing them ( slight smoking, not sure if it all needed a few miles to settle ??? ) all has been well ( fingers crossed ). i only now get a very slight puff of normal smoke on hard acceleration and gear changes at full throttle which im sure is normal........does any of this sound familiar to your prob ????.
regards, dave
Old Jul 30, 2006 | 06:17 PM
Avinitlarge
regards, dave
It does sound pretty much the same, Been out most of the afternoon and only got one tiny puff of smoke.
Does anyone know what the smallest size a catch tank can be??
Old Jul 30, 2006 | 09:42 PM
Avinitlarge
Just found the problem, I checked all of the breather pipes the other day and found no problem. A few days ago 2 of the breather pipes that go to the catch tank came off, Yesterday one of the other breathers to the catch tank came off and I left it off, Today I had no smoke, My brain finally went into gear and I found the problem, I checked summat I never thought of checking, The breather filter that had only been on for about 2 weeks, It was more or less blocked solid, Dont know if the glue that holds it together had melted or the filter element had melted but what ever, I could hardly blow through it.
Note for the future, Dont get cheap breather filters
Old Jul 30, 2006 | 11:37 PM
xrchris's Avatar
xrchris
this sounds similar to my problem. which breather was it in? i had a small pipercross filter on my top breather by the rocker cover and since it fell off somwhere it seems to have started smoking more.
may just be coincidence
Old Jul 31, 2006 | 12:07 AM
Avinitlarge
Ive got 2 extra breathers on the block and one on the rocker cover, All 3 go to a catch tank, There is a breather filter on the top of the catch tank, It was that which was blocked
Steve Escos
Oct 1, 2015 06:57 AM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Brickhouse
Sep 21, 2015 04:31 PM
Brickhouse
Sep 21, 2015 11:00 AM
