rs turbo problems
Old Aug 10, 2006 | 03:19 PM
  #41
SafeChav's Avatar
SafeChav
Where abouts is it sucking in air???
Obviously it shouldn't be...
Old Aug 14, 2006 | 06:27 PM
  #42
blackerst's Avatar
blackerst
the top boost hose which goes from the top of the intercooler to the charge carrier. its collapsing by the charge carrier
Old Aug 14, 2006 | 07:23 PM
  #43
SafeChav's Avatar
SafeChav
Nothing new if they are standard hoses. They go soft although its usually the hoses before the turbo that do it.
Samco time
Old Aug 24, 2006 | 02:32 PM
  #44
blackerst's Avatar
blackerst
ford cant get me the 1 way valve so ive got a xr3 fuel pump will this work also its satrted to get hard to start even when cold cheers m8
Old Aug 24, 2006 | 02:38 PM
  #45
SafeChav's Avatar
SafeChav
Have you tested your one way valve yet?
Old Aug 24, 2006 | 03:52 PM
  #46
blackerst's Avatar
blackerst
no coz i cant find the fuel pump
Old Aug 24, 2006 | 04:24 PM
  #47
SafeChav's Avatar
SafeChav
You can't find the pump on the car?
Old Aug 28, 2006 | 01:15 PM
  #48
blackerst's Avatar
blackerst
hi soz yea found pumpthe valve is ok but now my car wont start at all and when it does the dump valve aint woring and it runs badly for about 3 mins
Old Aug 29, 2006 | 09:39 AM
  #49
SafeChav's Avatar
SafeChav
Ahhhhhhhhh ok i got your PM the other day i couldn't remember which one you were (too many PM's )
To be honest sounds like theres something fairly serious wrong.
Have you checked the small vacuum hose for the DV is connected?
Old Aug 29, 2006 | 07:38 PM
  #50
blackerst's Avatar
blackerst
yea i have checked this and also checked with wd40 for air leaks any where else but when it does start it runs bad and after bout 2 mins of gently reving to 2000 rpm it runs fine but wont start when hot still any ideas
cheers m8
Old Aug 29, 2006 | 09:12 PM
  #51
SafeChav's Avatar
SafeChav
Very hard to say mate.
Very wierd ur DV is not working
Old Aug 29, 2006 | 09:47 PM
  #52
blackerst's Avatar
blackerst
yea tell me bout it its weird how it was running fine til my m8 changed the turbo and since then its not been rite i found out that the reason the boost pipe was collapsing was be coz he had the wastegate constantly open ive sorted this and its stoped collapsing. on the amal valve the pipe that faces straight up wot does this go to and also below the metering head there is some thing to do with the fuel system but it looks like there is a pipe that should go from this to the metering head
Old Aug 30, 2006 | 09:23 AM
  #53
SafeChav's Avatar
SafeChav
What you've said doesn't make sense, if the waste gate was permenantly open it would never boost..............
This is all getting very complicated and hard to understand.....
Matt Baxter
Sep 16, 2015 08:30 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
A.t.p
Aug 15, 2015 11:37 AM
druidgetafix
Aug 15, 2015 10:22 AM
