non starting focus
Old Jul 16, 2006 | 10:57 AM
davecosworth's Avatar
davecosworth
IM BACK
Default non starting focus
have a tdci that wont star just had the high pressure pump changed and reprogrammed the injectors but it is still comming up with fault code of ijector delivery pressure low it is now at 5200 kpa but wont star so i put a simulator on it and took the fuel pressur up but still nothink i am getting the smell of burnt diesel from the exhaust but it just wont fire. but if you tow it then it will start but runs rough and cuts out
Old Jul 17, 2006 | 04:01 PM
davecosworth
IM BACK
can any one help
Old Jul 17, 2006 | 08:18 PM
vyper developments's Avatar
vyper developments
can you give me more to go on? like was it all ok before you changed the pump etc? Why did you change the pump?
Mike.
Old Jul 17, 2006 | 11:49 PM
davecosworth
IM BACK
i changed the pump as the old one had chewed its self to bits and i had no fuel pressure 400kpa is what it read up as on my diagnostics machine and it wouldnt start unless towed but when you did tow start it it sounded like a bucket of shit and missfired. and now i have the problems that i have explained at the start. the fault cosde that pops up is low delivery pressure to injectors on cranking.
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Fordmad!
Sep 26, 2015 05:24 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
saph in dorset
Aug 14, 2015 10:10 AM
track.focus'd
Aug 12, 2015 05:53 PM
